you could make your own. just buy a regular one, stuff steel wool into a stocking, shove that inside, and adapt a small breather to the top.
*sigh* if only I wern't lazy lol
Might have to do that.... even decent normal CC's are hard to find at a non absorbitant price
Anyone know who sells atmospheric vented catch cans here in adelaide.. they're f**king hard to find
As damo said just make your own;
That's what i have done, Just tapped a thread into the top of the can and then screwed in a barbed fitting and fitted a breather. I also made up some internal baffles and baffled the top of the can where the fitting was screwed in then filled the can with steel wool. the can only cost me $45 from memory.
Edited by D_Stirls
its that good i need a second bag of popcorn
AleviAte7 wrote:Wow.......just joined this site......not sure that was good idea now......
rxbuzz wrote:
Well f**k off then. flamin mongrels like you dont help the situation.
lol
i love being the high bidder on an item from ebay for a whole week, after
putting on a ridiculous bid to make sure i dont get out-bid by 50c (always happens)
lol another trick is someone they know keeps bumping up the price and when they accidently win it themselves the item go's back for sale 2 days later.
post-31501-1239792607_thumb.jpg[
the battle continues, thread now stickied on their forum. ROTARY :down:
http://www.ausrotary.com/viewtopic.php?f=3...031&start=0
the battle continues, thread now stickied on their forum. ROTARY :thumbsup:
The more i read it the more it cracks me up :down:
front coils are in, had a few issues, took a couple hours, but is much awesome. :down:
question for all those coilover users out there though, the cusco's dont have this clip for brake line;
is that a big deal?
Edited by scandyflick
"and you are you?"
"we are the bedroom police. we clocked you at 1 min 38"
"i guess that is pretty fast"
"we'll let yuo off with a warning this time, but only if you contact ami"
hilarity :down:
Guest
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
