Good luck to all the boys going on the Toy Run today. Stay safe.
Yeah that Twilight movie was pretty shit to be honest. To much loving, not enough slaughter. Also its obviously going to be a series of movies be the end of it. Great :)
Lol. Like half way through the movie I needed to piss so bad, but I didn't wanna miss anything because Jen would of explained it all to me later. I love the " we can only play Baseball during Thunderstorms" bit.
i think may have been one of the many scenes where my attention waned somewhat.
the only thing that movie has going for it is the reasonably cool soundtrack.
now, 'in bruges', thats a cool movie.
i miss my stagea
want her back now
bets on dyno queen rwkw figure - I say 230 at 1.1bar this tune (poncams, head)
and perhaps 245 next tune (HKS AIC-4 additional injector controller, & Sard intake manifold setup with 2x700cc Sard injectors~ mounts near bov)
:sad:
I took my car to Pedders in Morphett Vale on Friday afternoon, good bunch of guys there. They spend an hour with me looking over my suspension looking for any problems and also got a very good quote on an adjustable front sway bar, when i left i asked them how much i owe'd them and they said not to worry about it. So if ya live down south i'd def recommend taking your car to them if you need any suspension gear :)
Edited by DSTROY
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
