Done a search already. Cant seem to figure out what this kit is called. Sooo many look alikes!!!
This one is a bit of a unique one as I notice it's got skyline on the bottom lip. anyone can tell me what this is called or where to get it? Thanks!
https://www.sau.com.au/forums/topic/188420-r34-4oor-kit-what-is-this/
front bar is a genuine Nissan Aero kit, with what looks like an east bear add on lip and also GTR bonnet with the top mole available from east bear as well to fill the gap between the front bar and the GTR bonnet.
Check out www.powerplayimports.com.au under R34 and East bear.
  • 3 weeks later...
Where would you go to buy the full kit of this?????????
looks insane
That car belongs to a member on these forums, his user name is GTX-R34
i know coz i approached him about his topmole...
He has an R34 GTT aero frontbumper (some ppl no it as the Nismo front bumper, not sure if thats what is it really called though) and it looks like he has a V-Spec R34 GTR lip add on...
U might have to ask him wat side skirts and rear bumper he has too..
Edited by DNGRUS
Yes, this is correct with factory skirts and rear pods but i've now added a genuine R34 GTR rear wing aswell. Took this photo this morning, bit blurry though. Please note; the GTR badge is only temporary as i'm still trying to find a replacement for my stolen one.
that looks awsome. i have a 4 door r34 as well and ive been looking for a gtr vspec front lip that attaches to the front bumper they look awsome, does anyone know where to get one? also would it attach straight onto my normal front? in my mind it looks good i wonder what it would really look like.
the bottom lip can be purchased from powerplay imports..its a genuine east bear item around $600 excluding fit and paint...there are two types, one to fit the factory standard bar and the other to fit the nissan aero bar..looks awesome but makes the front really low...
my car is still at its stock height so it would fit ok but then i was thinking it wont line up with the rest of the body so i would have a low front and the rest would still be high. but then again it makes it look sooooooo awsome. i might have to photo shop and try and see what it would look like. thanks for the info as well.
Ah your car looks awesome dude. I'm getting a R34 soon and thats my future plans...can I ask u how much this set u back? Thanks.
Thanks champ, sometimes i think i might have gone too far but once i started i just could'nt stop. As to how much have i spent, you don't wanna know.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
