I heard the trust type M dont need the fan blades to be cut.. Obviously you will still need to cut a hole for the piping on the side..
Or you could get return type coolers such as ARC.. But will be expensive..
Otherwise most cheap copies, will require you to cut a bit of the fan blades..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3398401
Correct siddr20, the Trust ones don't need the blades cut nor do the GReddy's but I beleive they are the exact same just rebadged
So your sure that the Trust/GReddy ones don't need to be cut? even for the NEO RB25?
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399303
series 1 r33 here and i installed a JJR intercooler kit...didnt have to trim the fan blade and it doesn hit either...even underload
i believe the s2 is the same deal...although some people say that it hit, some say it didnt. If it doesnt have clearance you can always gently notch in a small dint in the underneath of the piping with a peice of wood to make it clear....someone i know did that and it clears now and no need for fan triming :rolleyes:
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399618
Just a get a Blitz LM cooler or ARC, with return piping so no need to cut holes or fan. And it should run more efficient since it doesnt sit above the rocker cover or radiator.
ok, noob question.. Return piping?? I've heard ARC are sweet intercoolers, but what is return piping???
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399880
Yep, BLiTZ M is good, thats what I have on my R32, well whats going ON my R32.
Attached a picture for you noob :thumbsup:
Thats the cooler that will be going on my R32, you can see how the piping comes to the one side.
Return flow is when the piping runs to one side of the car, and up into the engine bay the same way the stock I/C piping does.
Abu
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399965
I've got the Blitz LM kit on my R34.
I'm at work atm so this is the only pic I could find.
Sweet setup bro, what ius that thing just to the left (picture, not car left), of the intercooler??? Oil Cooler???
@ Abu.
I see mate, thanks!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401448
I'm gunna jump on the wagon too..
I also have R33 GTST S2, 40th anniverssary (though pretty sure it's the same)
Was thinking of getting greddy 300x600x76.
Should I expect any increase in lag with this cooler?
If so is it worth changing to the R34 GTT one?
I dont plan on going crazy with mods for more power in the near future, maybe just a pod filter and I already have 3" exhaust.
Also any other basic tips would be appreciated..
Thanks in advance!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401503
i've certainly noticed more lag after installing my fmic - eventually i'd like to go to a front facing plenum to reduce the pipe-maze a bit and see if it helps. also am going to wrap my return pipe in front of the radiator in heat-proof shielding to see how that goes cos that pipe gets stupid hot!
oh also have a jjr fmic and just bent the bracket that the return pipe uses to attach to the engine so it clears the blades - looks a little ghetto but looks aren't my concern.
Edited by made_guy
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401566
Thanks guys..
I am also taking into consideration that I live in Alice Springs and it gets DAMN hot and dry. I don't know how this will affect my car...any ideas? I don't think it will be too much of a problem, maybe just a little loss of power..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3402209
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
