Settled on one of the GT30 hi-flows from ATS, price was right, could fit me in basically straight away and will give me enough power that I'll be happy until I step up to a GTR. Just need to get some bigger injectors to fully utilise the power of the turbo
  • Replies 129
Posted Images
NEW Booking Details
Hi guys its that time of month again,
now I'm thinking because were coming to the end of year i may just go ahead and book for 20 seats and hope we fill them
Table booking name Skylines Australia
Dinner: 7:00 - till all are finished
Where: Royal Hotel 2 North Tce
Kent Town, SA 5067
(08) 8363 4888
I'm not really keen on bowling but i know a lot of you guys do enjoy it so I'm not sure if you would rather a cruise afterwards for go bowling maybe leave that up to a vote
Madaz +2
Heslo
Whiplash - PAID
pkblade - PAID
Hotwire +1 - PAID
Kroozin - PAID
Evil34 - PAID
*flick* - PAID
skylineguy19 - PAID
trick - PAID
jugz - PAID
Bunny33 - PAID
Nightcrawler
kalel
4door_Sleeper - if car is fixed
Are the last 3 coming steve?
Hey Steve, unfortunately something has come up and I can no longer make it tomorrow night! :)
PK paid my $5 deposit, so is there anyway he can be reimbursed for that, otherwise I will give him the $5 when I see him at SCS.
Hope you all have a great time and safe kroozin!
i was planning for a cruise but alot of people are pulling out so not sure :)
i told my daughter we were going down to see the penguins but if no one wants to go i told he maybe we go to the beachhouse instead
Crap Steve sorry but looks like I gotta pull out again, this time it's for family reasons. My grandma is in a bad way health wise and we are going down to see her but I don't know what time that will be over... sorry matey :)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
