Hi guys,
Just a quick few questions:
1. Is an 'extension kit' the same as dump pipes? (im guessing its just a different name) - Im specifically looking at a HKS set.
2. Where can I source (if anywhere) dump pipes within Australia? Not interested in eBay MONSTA brand stuff. I want quality and proven direct fitment. Not 'hope and pray' gear.
3. Anywhere from O/S worth sourcing from that have a decent (less than a week) delivery time?
Cheers!
Dan :happy:
https://www.sau.com.au/forums/topic/188585-dump-pipes/
i got the just jap ones and there great.but make surer ya get the r32 gtr ones,i got the 33 ones and had to change them
Oh awesome i ordered a set today. Which ones did you get though? They have like 5 diff ones....
Yeah Monsta ones are SHIT! I got some cheap cheap and they were both identical (sposed to be different) and then they sent me another set exactly the same! :@ got a refund at least.
https://www.sau.com.au/forums/topic/188585-dump-pipes/#findComment-3400732
Can people confirm the Trust dumps are a ball-breaker to fit? Or otherwise? I am not fitting them myself, its a performance workshop, if that makes a difference. (Ash?)
Im guessing that the Trust would be better in terms of quality and performance over the JustJap ones, but is the cost difference worth it? Or am I not even going to notice. All other supporting mods are in place.
Also - costs of the Just Jap ones?
Cheers!
Dan
https://www.sau.com.au/forums/topic/188585-dump-pipes/#findComment-3400763
Cheers!
Dan
I was the one who fitted them :wave: on a GT-R it would be a nightmare. go with the x force ones
https://www.sau.com.au/forums/topic/188585-dump-pipes/#findComment-3400872
not 2 sure now but i no i had to makeup a reducer out of the bungs in the 02 sensor holes as i must have got the 33,34 gtr ones cause the holes where to big and the old dumps reducer didnt fit.other than they fit sweet as
https://www.sau.com.au/forums/topic/188585-dump-pipes/#findComment-3401520
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
