Hey guys im looking at getting some new GN+ 5ZIGEN The size i am looking at at is 17x8.5 +30 offset all round i was wondering if any of u guys would have an idea of if they would fit without modifications my car isnt that low atm so i cant see it being a problem any thoughts would be helpfull
cheers wes :wave:
https://www.sau.com.au/forums/topic/188653-new-rims/
not sure i have a r32 4 door
with old enkie 16X8 on the rear - without lipping the gaurds they wouldnt fit with 225 tyres had 205s to start with fitted fine - not sure what the offset is
fronts are only 7inch wide 8s wouldnt fit too well on the front
my offsets are probably wrong
have seen 255 tyres on 17in rims on a 32 4 door would be 9in rims i would think and they were rubbing but only just
https://www.sau.com.au/forums/topic/188653-new-rims/#findComment-3401376
cheers wes :yucky:
fit no problem! no mod required
https://www.sau.com.au/forums/topic/188653-new-rims/#findComment-3401444
I currently have;
17x8 +30 on front
17x9 +30 on rear
my car is lowered to 340mm and due to the soft damper, just a bit firmer than stock suspension i get scrubbing.
I get scrubbing on the front and i have 8inch, whilst yours are 8.5 even larger.
If your suspension is stiff it shouldn't be a problem
https://www.sau.com.au/forums/topic/188653-new-rims/#findComment-3405840
Tried my 34 GTR rims on a clients 32 gts-t .. no rubbing
im running 17x 9's they fit easily
tis only when ya look at 18 + that ya might need guard rolling
What offset they have ??
ive got 18x7.5 or 8 on mine and only had to make some 10mm spacers for the front to clear the calipers and didnt need to roll anything
https://www.sau.com.au/forums/topic/188653-new-rims/#findComment-3406432
I just ordered some of these in 18"x9.5 +22 off Nengun for my GTR
Should look mint.
There pretty hot hey i wish i could have that offset and width :( so do u reckon +30 would still be an alright bit of dish for these sought of rims?
gotta show me some pics wen ur done :wave:
https://www.sau.com.au/forums/topic/188653-new-rims/#findComment-3414660
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
