I dont think they are open anymore, or atleast not doing that well... I havent seen them down BWCP in about 18months either.
hey josh ttr are great company :closedeyes::spam: (joke)
remember when a certian person was telling u and your dad that it was fine to run a td06 on a rb25 with stock injectors and i said other wise and what happened to the motor after it ran down willowbank ?????
but meah sooo long ago and the memorys i have of that place
but to the guy that want to do this conversion theres plenty of sau members that will offer and hand to to the job some will offer great advice also if u want to learn about your car this is a great way to find out
Can help with the wiring. I have done a few now. Excellent conversion, I even did one for my fathers R32 at the start of this year. He loves it!
I have personally done 2 now and have done them over a weekend with a hand from my bro-in-laws.
Cheers
I've heard nothing but good comments about this man, however make sure he leaves the brother-in-law at home :closedeyes:
i have done a few of these conversions now.
if your after a harness, give me the RB20 engine loom, and the RB25 loom and $350 and you'll have yourself a complete wiring loom that plugs stright on. if you have an R33 microtech, is it plug and play? If so, then as i stated above will be the way to go.
As for the motor, it will bolt stright onto your crossmember, however, as stated earlier in this thread, you will need a modified gearbox crossmember.
I can also do your tailshaft, as mentioned by showbag on the 1st page, i do tailshafts for a living, and trust me, you dont want to do any dodgey stuff in this department. I can build you a complete 1 piece tailshaft, brand new that will cop 350rwkw for $450. I use billet slip yoke and high tensile steel tube.
If you need intercooler pipe modification i can also help in this department, as with the exhaust, but the RB20 exhaust will bolt strauight up if both your RB20 and RB25 have standard turbos.
PM me if you need anymore info, i'll be glad to help.
Edited by blv
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
