Yesterday i was going down reid hwy and hit a prob when the engine light came on. when i stoped it was idling strange i stop the motor and poped the hood nothing seem to look out of place. once i started the car again it was all back to how it sounds every day ...
should i get some one to have a look at the car
Or just wait to its next service?
https://www.sau.com.au/forums/topic/188889-stress/
did it start sounding like a wrx? if so its a coilpack..i went through it 3 times with my girl b4 putting in splitfires
sounding like a wrx could also be a dead sparkplug giving you 5 cylinders. It sounds cool but yer it isnt :)
check your plugs as well ron
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3407091
it could be many things man...rings/coil packs/spark plugs...when mine did it....it was because i got water into the spark plug area and it couldn't fire properly but yeh haha just check out the coil/spark plugs area :) hope that helps ron
Cheers
Chi
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3407612
I had a brand new impreza do that to me before- turned it around to dealership(where i worked) grabbed another car. Service guys took it for a thrash and somehow that solved the problem...... don't blame me if you blow something - it just happened to work in this instance - they didn't have much of clue what it was either.
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3408489
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
