Yesterday i was going down reid hwy and hit a prob when the engine light came on. when i stoped it was idling strange i stop the motor and poped the hood nothing seem to look out of place. once i started the car again it was all back to how it sounds every day ...
should i get some one to have a look at the car
Or just wait to its next service?
https://www.sau.com.au/forums/topic/188889-stress/
did it start sounding like a wrx? if so its a coilpack..i went through it 3 times with my girl b4 putting in splitfires
sounding like a wrx could also be a dead sparkplug giving you 5 cylinders. It sounds cool but yer it isnt :)
check your plugs as well ron
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3407091
it could be many things man...rings/coil packs/spark plugs...when mine did it....it was because i got water into the spark plug area and it couldn't fire properly but yeh haha just check out the coil/spark plugs area :) hope that helps ron
Cheers
Chi
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3407612
I had a brand new impreza do that to me before- turned it around to dealership(where i worked) grabbed another car. Service guys took it for a thrash and somehow that solved the problem...... don't blame me if you blow something - it just happened to work in this instance - they didn't have much of clue what it was either.
https://www.sau.com.au/forums/topic/188889-stress/#findComment-3408489
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
