Sau Sa Track/social Day + Bbq! - 27/10/07
Sau Sa Track/social Day - 27/10/07
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 218
Posted Images
ive heard 29 deg all day
all the drinks have been bought get the meat sat morning and the bread fri or sat and some onions sometime too :)
i will edit the list again and repost it up later cant be bothered right at this minute :) dinner tiome shortly :D
I will be coming out with my Lancer, a few other mitsi boys are coming too. It should be a good day there will plenty of japanese beasts there.
i hope it doesn't get to 33 degrees though.
Sorry, no Evos!
This is payback for last time you didn't let people with GTS-ts drive. HA! :)
Think I'm not gonna drive this time, better take it easy with the new engine for a while first.
Edited by salad
anyone know what time it finishs. i got work till around 1 or 2.
Yeh generally around 4ish maybe 5!!
so whats the plans, when it gna be, how many people, who driving, bbq?
It's gonna be in 2 days time(Saturday), heaps of us(plus other people as its a general track day not just SAU) few driving, and yes BBQ will be there(plus drinks but no bar) Which reminds me, If you are to bring Beers or something similar you know the rules "Not in the pits" but thats not the end of the world!!
can we set the BBQ up anywhere we like I'm thinking near the mount on the entrance to the main straight?
You could do Steve, BUT id suggest just setting it up in the pits as there is a official lunch time, which will suit the people driving, and besides during the "lunch time" there will be nothing on the track, so sitting on the mound/hill with nothing on the track would seem pointless!!
Check that map you put up Steve........ Must be Skaifes racing lines! Check turn 3, there in the inside blocking from half way down the pit wall......LOL GHEY!!
Edited by Deluxe
Darren you know how you come from the pits then up some wooden sleepers onto a grass section tbefore fence for track what about there and where can commoners park i dont want to be carrying bbq for miles to get there can i park up near pits
Yeh mate sounds like a plan........ on a Practise day mate you can park right up in the pits if you like, Nobody controls the pit gate on Prac days, I would suggest to some of the others to park in the pits also, but still making it accessable for the people(also non SAU people) that are driving, mind you there is plenty of room for everyone!!
People on the BBQ list
salad - eating
Cubes +2 - eating
gtrkiet + 2 - eating
boostdq +1 - eating
Madaz - eating
bezender - eating
*flick* - eating
Deluxe +2 - eating
SimonR32 +1 - eating
skylineguy19 - not sure no update as yet
RyanRB25 - eating
dnbutts - eating
nisskid (driving) - eating
richo - eating
Mobies (driving) + 2 - eating
BOOSTD (driving) - eating
thanglongz +2 - eating
so thats 26 people for the BBQ? with skylineguy19 not having updated if he can change his roster
any updates to this list can still be made until tonight LAST UPDATE tonight i will look @ replies and adjust in the morning i will be ordering the bread this afternoon
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
