hey guys, doing more of a clean up now so more parts must go!!
R33 series 2 turbo with standard dump attached and r32 gate on it (10psi) = $350
R33 Elbow (needed to fit turbo to a R32) = $50 ($20 if bought with turbo)
3" Front pipe (in between dump pipe and cat) = $100 (or $450 for the turbo,elbow and front pipe)
GTR standard camshafts = $150
R32 GTST standard fuel pump, was working fine for me. = $50
Standard SMIC, with some piping = $50
Standard Exhaust manifold = $30
Upper Control arms with BRAND NEW nolathane bushes, never been used = $100
Standard AFM, also ran fine in my car = $50
Standard R32 gtst turbo = $150
Mines tuned ECU = $500
Standard R32 ECU (no speed limit) = $150
VG30 turbo, would be good to highflow. = $150
RB26 Gearbox with transfer case blocked off = $650
all parts are located 1hr west of brisbane.
please PM any questions. i am negoable on all parts to a point.
thanks
CJ
ps, can do a deal if more then 1 part is bought at once. :)
Edited by -_-StRyDeR-_-
https://www.sau.com.au/forums/topic/189174-parts-clean-up/
Also got a brand new water pump for a rb20det, paid $160 from repco, will sell it for $100.
and sorry to put a dampener on things, but people that are interested in the turbo, id really like it if you can come and see the turbo itself, i dont like sending turbo's as the buyer might complain about what he/she paid for.
thanks
CJ
https://www.sau.com.au/forums/topic/189174-parts-clean-up/#findComment-3410700
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
