hey guys, doing more of a clean up now so more parts must go!!
R33 series 2 turbo with standard dump attached and r32 gate on it (10psi) = $350
R33 Elbow (needed to fit turbo to a R32) = $50 ($20 if bought with turbo)
3" Front pipe (in between dump pipe and cat) = $100 (or $450 for the turbo,elbow and front pipe)
GTR standard camshafts = $150
R32 GTST standard fuel pump, was working fine for me. = $50
Standard SMIC, with some piping = $50
Standard Exhaust manifold = $30
Upper Control arms with BRAND NEW nolathane bushes, never been used = $100
Standard AFM, also ran fine in my car = $50
Standard R32 gtst turbo = $150
Mines tuned ECU = $500
Standard R32 ECU (no speed limit) = $150
VG30 turbo, would be good to highflow. = $150
RB26 Gearbox with transfer case blocked off = $650
all parts are located 1hr west of brisbane.
please PM any questions. i am negoable on all parts to a point.
thanks
CJ
ps, can do a deal if more then 1 part is bought at once. :)
Edited by -_-StRyDeR-_-
https://www.sau.com.au/forums/topic/189174-parts-clean-up/
Also got a brand new water pump for a rb20det, paid $160 from repco, will sell it for $100.
and sorry to put a dampener on things, but people that are interested in the turbo, id really like it if you can come and see the turbo itself, i dont like sending turbo's as the buyer might complain about what he/she paid for.
thanks
CJ
https://www.sau.com.au/forums/topic/189174-parts-clean-up/#findComment-3410700
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
