Yes it will hold it at 10psi, even WITHOUT a boost controller.
A boost controller will on increase from the base level of whichever actuator you are using.
Like the R33 which is 5psi, and then the boost solenoid gets it up to 7psi.
Therefore, if you only switch the actuator, it will go from 10psi low revs to 12psi when the solenoid kicks in at 4500revs.
im in the midst of putting the r32 actuator on my car now. it is a direct bolt on and if u only want it to run the actuator pressure u just run a hose from the actuator to the cooler pipe nipple and thats it yeh? so it will be 10psi? i dont wanna run 10 then 12. stock turbo would prob go knowing my luck.
gttr34 not sure if they are interchangable with the 32 actuator. if ur in melb ur more than welcome to see if my 33 actuator fits your 34. if it does, well the the 32 actuator will fit too.
Hey dude, i know im off the topic but cuz i just read ur mods and saw the high flow panel filter, does it make a nice loud woosh sound just like the pod style air filters???
mine makes the induction noise only coz i have a few 1.5inch mesh holes cut out around the lid of my air box. personal mod. it still allows extra air into the box while mainting its approval to the epa and allows induction noise.
Edited by cheez
Might aswell get a pod I guess cause your still going to suffer from heatsoak I believe.
its not that bad, i dont feel any difference from having a pod and having my airbox with duced holes. at the end of the day the box is probably better as it still has the front duct on so takes cold air in majority of it, from the front. and also, cops cant touch the car as the airbox is epa approved even with my mods to it.
How about for GTT R34's?? Will i be able to use the 32 actuator on the GTT R34? And if i do how will the boost stages and etc work out to be?
I've installed one on my R34. You'll run approx 12 PSI and it's a direct bolt-on, no modifications needed.
Edited by ztune_R34
i put a r32 actuator onto my r33 and it went straight to 15 pound not good on stocl turbo and ecu no matter what i did i could not get it any lower. bleed valve had no effect . in the end i took it off put the r33 one back on and used a bleed valve to get it to go to 10 pound runs sweet now
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
