Hi,
I have made my own intake plenum for a rb20 but need to welded up, just wondering if there is a SAU member around the Mt ommaney area who can weld alloy pro like? or know any business's who will weld it up for me?
Cheers
Cameron
https://www.sau.com.au/forums/topic/189356-alloy-welding-westenr-suburbs/
Only know northside myself, but if you get despirate there is a joint at Brendale that can not only weld it for you, but flow test it before you put it on the car to see if its any good...
I am up on the north side very oftern, whats the name of the company i will give them a call
cheers
www.are.com.au
PH: 3205 4620
They make custom pleniums for unusual applications, look at their customer cars area of their website and you will see what they do.
They so allot of work for heaps of race teams with a drag racing heritage...
When you ring ask for Richard, tell him Col sent ya...
How "west" do you want to go. 2 out here in the switch that can take care of it for you. Both make plenums and manifolds etc.
Signature performance (Ask for Mic)
Lobb st
Ipswich
Scotts Rods (Ask for Scott)
Belar Street
Yamanto.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
