Ive just purchased a 90 cefiro a few months back. It was a NA with RB20E engine previously but the owner converted it to RB20DET and he claims that the car has a viscous lsd. How can i confirm that it has a viscous lsd? If it doesnt have one in it, is it recommended for me to install a R32 axle?
https://www.sau.com.au/forums/topic/189493-how-to-check-for-lsd/
do a burnout ..... if both wheels spin together as one its a lsd :D
lol. or you could jack the back of the car up. grab hold of one of your wheels and turn it. if the other wheel spins the same way its a lsd. if the other wheel doesn't turn or turn the opposite direction its an open center.
oh yes that too :D
Depends whether the car is fitted with a 5*1 or 3*2 bolt pattern driveshafts.
S13s use the 3*2 bolt pattern, and R32s use the 5*1 bolt pattern. Just swap in an LSD from either one depending on what bolt pattern your driveshafts have.
Also, just to clarify, they don't have an axle as such because of the Independent rear suspension, it has the diff and 2 driveshafts (sometimes referred to as CV's, because they have CV joints in them).
Axle usually refers to cars that have a live axle (solid axle) such as KE/AE corollas for example.
Just have a quick look under the rear of the car, you'll see each rear wheel has a driveshaft (with CV joints) coming out of it.
The drive shafts then bolts onto the half-shafts that come out of the diff.
There are 2 bolt patterns for the halfshafts/driveshafts.
5 bolts evenly spaced, or 6 bolts arranged in 3 pairs.
S13 uses 3*2, and R32 uses 5 bolt. Most A31/C33 I've seen use 3*2 but have a look under the rear of the car and check.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
