Discount price to 3800 with tyres
REason for ruduce because i got many emails and SMS that asked me about without tyres,so i have to take it off very lazy so pls let's me know which way do u need.
Price firm because few people ask me just 2K. I open to neg but please nearest from the price that i've set. if u r one that crazy for top secret u ll understand but if u dunt know what does it mean???!!! u should buy TE37 even (te37 cost more than 2k) Maximum width for LE37T is 9.5 gold finish is 8.5 if u want some unique pm me i'm waiting
thanks
Regards
Edited by em456
brand and size of tyre? How much tread?
Are you saying that the tyres are only worth $200?
what did these come off?
Thanks
Hi
I' dont know how to estimate the prices of tyres actually i'm very lazy to take it off so i just set 200 different 3tyres is good 80-90% left but the other one around 70%
Tyre Brand
Bridgestone Potenza G2 and
1Dunlop Lemans
Sorry that i made mistake abt message :dry: i thank shakeil becos we have to contact for a long time and he offered the price that i agree with and he definately want to buy but unfortunately These set cant fit with the GTR32.regret for him he definately want to go with TS.
Edited by em456
I've seen these at Powerplay... absolutely IMMACULATE rims..
Yes, thank you. I left it 1 rim overthere with "jo ann" Problably will going to get it back in a few day.
Edited by em456
Come and take it with 3000 with tyres Price will rising after 17/11/08
New one For these width and offset 1100 each w/o Tyre and Shipping.
SMS pls
Edited by em456
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
