Hey all,
Just finished reading the 'What should I get first?' thread: http://www.skylinesaustralia.com/forums/t45218.html
But what I'm asking is what I should do next, or what would you do next if you were in my position.
Okay, I've got a s2 R33 gtst, so far it has:
apexi fmic
3" exhaust (split dump pipe, 3" cat, 3" cat-back)
hd clutch
spitfire coils
k&n panel filter (tried running a POD, but saw better results with std airbox + panel)
I personally was thinking maybe a PowerFC or even a SAFC2. Or perhaps just a manual boost controller. However, if you think there are mods which will be give me equal or even better gains than these, then I'd prefer it, as my insurance co. (HBF) does not allow any sort of boost controller or replacement/piggyback ECU.
So... If you were me, performance wise what would you do next. Money isn't really an issue. I dont mean that as in I can buy anything. I mean it as in the more expensive the item is, the longer I will wait (and save up) for it.
Thanks heaps :D
https://www.sau.com.au/forums/topic/189893-need-some-advice/
or get a 10psi wastegate actuator from an r32, and get your standard computer remapped (i think dr drift can do 33's now), that way your insurance company will never know. also i would look into the suspension and brakes
Edited by Green_s13
I would get:
1) A new insurance company
2) New shocks/springs if not already replaced
3) Upgraded brake pads, maybe rotors (just on the fronts).
4) If you did 1), then whatever you like from here :) I'd say ECU/chip. You're in the same spot as me, only I've done 2) and 3) and boy do they make a difference.
Thanks for the replies so far guys.
Without a PowerFC/SAFC, i can't really expect to get more gains KW-wise, is that right?
I was planning to do the brakes/suspension anyway, so at this stage I'm really just interested in what would give me the best gains kw-wise.
yeha you're pretty stuffed if you can't get a powerfc or Tunable ECU unless you want to get a remap. BUt they aren't exactly as easily tunable as a powerfc.
www.justcars.com.au
www.shannonsinsurance.com.au
lol I don't know if they are the right links but you get the idea.
Yeah I think I might settle for an EBC + powerFC. I hear they are hard to come by (PowerFCs) as they are discontinued, i know someone who is selling it without the hand controller. This is still okay right? As I wouldnt change the settings on the controller anyway.
I took the car down to the tuners last week and I was told it was running 1 bar of boost (about 14 psi if im not mistaken) - how is this possible if my car has no electronic or manual boost controller? not sure if it has anything to do with my car running dangerously lean (it has since been fixed).
(Excuse my noobiness as I'm still trying to get my head around all of this)
Also, would you guys recommend putting in an aftermarket turbo in before an ECU. (Basically want to hold off getting an ECU for as long as possible due to insurance complications)
you'll be able to syphon more power out of a After market ECU and stock Turbo than a bigger turbo and stock ECU.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
