HI guys looking at selling my rims to make way for some new ones. They're Volk racing light wieght 3 piece. imported them from Japan. 16 X 8 +30 and 16 X 7 +30 (i think). ill double check that when i get home.
The tires alone are worth 600 bucks a corner (Potenza RE01-R's 225 back 205 front semi's) and are the grippiest things ive ever used. They are a Jap tyre and can't be bought from australia. They shot me to a sub 2 sec 60ft time with 160ishrwkw. Sit perfectly on a standard 180sx
Looking for around $800ono. price is negotiable so let me know ur offer. no. 0431 466 113
cheers,
-Brendan
Edited by Big_fella300
https://www.sau.com.au/forums/topic/189968-volk-racing-3-piece/
hmm by the looks of things he's from VIC (by the plates) and probs a 4stud unless a 5stud conversion has been undertaken...wouldnt seperate the tyres would ya?
pretty easy to redrill i believe. not sure on price but not overly expensive. ill try to find out for you. may separate the tires depending on price offered. let me know
cheers
-Brendan
redrilling is easy, keeping the wheel strength is a different story i guess. any wheel repairer could do that for you easily. freight is going to be something circa the $150 mark pretty much aus wide using freight company for infrequent usage (businesses get better deals coz they are frequent users)..
how much tread of the tyres? to tell the truth im only after the rears at the moment coz the front ones are way too small for me. i will PM offer depending on tread. thanks brendan
looks like it will be somewhere between $80 to $120 to redrill. any local tyre place should do it. i know tempe tyres will. and as i said, the center caps cover the studs anyway. let me know if you're interested.
cheers
-Brendan
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
