Make: Nissan Skyline
Model:R32 GTR
Milage:92,000
Colour:Gunmetal Grey
Currently registered?YES
Price: $29,500ono
Contact: Jeremy 0414879711
POWER
419AWKW @25psi TUNED BY TM AUTOSPORTS at Tuggerah 43530733
Wheel spun 1st gear and ran 10.989 @ 130mph on street tyres with all interior + sound system in car minus spare wheel.
see bottom of page for video. only ever had 6 drag runs, never been on curcuit or drifted
ENGINE rebuilt 10,000ks ago with new bearings put in 3000ks ago when fitted tomei oil pump
(i have never killed any bearings, when i first built the engine i didnt know about the common rb26 oil problems. so i pulled the crank out and put on a JUN collar and Tomei oil pump (upgrading from the N1 pump i had on it) fitted an oil restrictor and external oil return, and i thought for the sake of 150 dollars i put some new bearings in. every one has been worried that the engine might have failed. which it hasnt.
Call me if you want to discuss 0414879711
cheers
Jez )
RB26DET APEXi power fc
Garret T04Z AR .70 front AR 1.0 rear running 25psi
50mm external wastegate both on custom manifold all PRO COAT ceramic coated
engine 40 thou over size
JE pistons, prepped rods and crank all balanced
ACL race bearings
Tomei Metal headgasket 1.2mm and metal manifold gaskets
ARP rod bolts, head stud kit
Tomei Oil Pump (the unbreakable one) with external oil return from back of head to sump
Tomei Sump Baffle, 1.5mm oil restrictor
N1 water pump
tomei poncams 260 9.15
800cc SARD injectors
3.5inch APEXi exhaust with magic catalytic converter
044 pump with sard fuel pressure regulator
oil filter relocator kit
split fire coils
hybrid 3 stage boost controller
RUNNING GEAR
Os Giken twin plate clutch
New front diff
New rear diff
DIRTGARAGE 2 wheel drive/4 wheel drive switch plus Attesa controller
Hicas Lock bar and all 4wsteer gear removed
CUSCO coil overs fully adjustable
rear camber adjusters
INTERIOR
stock 32GTR interior in excellent condition
Pioneer headunit, front and rear speakers running off Pioneer amplifier
Nismo boost gauge and air/fuel gauge
EXTERIOR
Excellent condition, standard paint job with 2 small dents (front left guard and rear right guard) which were there when i imported it.
one thing wrong with outside of car is front lip missing.
This car does not attract police hence the number plates (DVS32R) DEVIOUS 32R
please call me if you want to arrange a meet,
please do not call me if you want to joy ride.
Cheers Jeremy
10 SECOND VIDEO
CLICKY CLICKY my car is the grey one, XCALABA is on the right and blows 1 of his turbos near the finish :P
Edited by DVS32R
https://www.sau.com.au/forums/topic/190122-419awkw-10-second-street-r32-gtr/
I've seen probably every run this car has done and it's absolutely fantastic to watch and goes like a rocket on a relatively road setup.
thanks benm,
dyno sheet will be posted up tonight with some pics of car.
free bump... i dont like your chances gettin in the 30s for it but wish you all the best
thanks mate, im starting to think the same thing.
NEW PRICE $30,000
call me if your interested, 0414879711
need it gone picking up new car next week.
Lots and Lots of money put into this car,
comes with spare parts such as stock GTR wheels in white, heaps of stock parts if you want them with car, also N1 oil pump,
gl with the sale, would have been mine if it were selling 6 months ago..
Sorry to track off the subject, is there any chance you have a photo of th stock wheels in white?
Car Still for Sale.
car is at oldies place in garage cause i got my new car now in mine,
when i go there next i will take a photo of stock wheels in white, suits it quite well cept for the fact they look so small
I may have missed this above, but just a few questions....
What Year is the car?
What crank are you using?
What block are you using?
What brakes are on the car?
Any work done to the Gearbox?
I'm looking for a circuit car, and trying to minimise any additional purchases...
Edited by TwinTurboCelica
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
