Forsale is an as new gcg ball bearing hiflow turbo for an r33gtst. This will bolt straight onto standard manifold and includes all lines and a heavyduty xtr actuator. Turbo has seen only approx 4000klms and has no shaft play at all and turbo still looks brand new
looking for $1500 ono
located in the sutherland shire nsw.
pm if interested
Edited by robbo33
https://www.sau.com.au/forums/topic/190126-as-new-gcg-hiflow-for-r33gtst/
mitch this turbo is capable of pushing around 260-280kw easily.
Friend had it on his and i have driven it (same turbo as this guy is selling) and man it pulls hard!!
wish i had the money otherwise i would have bought this turbo.. but no job :blush:
yeah sidd ive heard some lucky people pull around 260-280kw
but than some people having like 230kw at 16psi?
need to justify if its worth the money to push around 260-280 like u said cause i would be mega pissed if i brought somthin like this, forked out cash for 550cc injectors z32 and only got like 25rwkw more than what i have now
mitch, it comes down to the tuner.. trust me
Get it tuned same place you got yours tuned at, and it will easily reach 260..
So jealous tho.. wish i could afford a hi-flow..
to much for a highflow mate. u can buy a 3040 or 3675r for that price
Hi newbie, you should learn to keep your opinion to yourself, what he is asking is about average price, comments like that will get you banned.
yeh mate thats if you want 350rwkw and then you pay for water and oil lines, cooler mods because the turbo is so big and a new manifold.
this is a complete bolt on ballbearing hiflow, good for 250rwkws. it cost $1950 brand new. this is $1400 and you can sell your orignal turbo so really its only about $1100
hey guys im kinda interested. ive heard for the same boost these highflows will make more power than a stock turbo. so if i were to run this turbo at 10psi, would my r34smic be sufficient to cool? what's the highest boost i could run b4 the cooler holds me back?
no not the same turbo. that was a garrett turbo that had been hiflowed by gcg.
this one is a stock r33 gtst turbo hiflowed by gcg. they have different serial and part numbers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
