I was looking over my battery the other day it has an earth kit but there isnt a -ve cable connected to the battery is this bad even though i have a n earth pack.
Also the car has had a miss for the last couple of weeks but on friday the car keeps surging while driving and just dies at the lights when i pull up. Also has little mental fits and wont go over 2500rpm.
Ive changed the following.
Fuel filter
spark plugs
cleaned the afm
and the idle solenoid thingy
had a look at coils took one off at a time and noticed 5 wasnt firing so I bought a coil from nispro still running shit.
reset the ecu
Edited by devos2be
https://www.sau.com.au/forums/topic/190258-ok-todays-mission/
OK no the earth pack is sweet But heres a real problem today i thought i would try and solve my miss fire problem. I pulled everything off got all the coils out had a good inspection at all of them. Noticed also there was an oily no.6 spark plug ,I was reading some of the syptoms and it said ,bad internals or wrong fuel/oil ratios can anyone help me with this new ongoing problems im having with my car.I did just recently change the oil . I'll try another oil change 2mrw and buy a new spark plug.
Ok will do that first thing monday .
Today i was going to check the ecu codes! Apart from the coil problem im having .The car in the past 2 days has been dying completly when im just about to stop at the lights or when im just cruising it will just start to surge on and off throwing me head around like a rag doll. Then it will either come good or just die .All the dash lights come up so i dont think its the battery ,changed the fuel filter spark plugs about 1 mnth ago(hoping to solve the problem no luck) .Yesterday checked all the coils took out all the spark plugs No.6spark plug was black and smelt like fuel/oil.Cleaned AFM it was covered in heaps of black shit. cleaned pretty much all of it off.Cleaned the idle solenoid thingy(picture)Put it all back together started her up pulled the plugs one at a time and coil 5 wasnt firing wich means its definately a coil if 6 had the black spark plug. Ive been reading a fair few posts and I think my problem with the car cutting out is a different problem. Because ive had the shit coil for about 2mnths now this has just popped up.
Either:
1. Fuel pump
2.crank sensor shat itself
3. Please add
will add a new pic in 20mins charging camera
Compression test on monday
Edited by devos2be
yeah the engine dying problem just came out of the blue but the missing problem was like 2mnths ago.
I did put it in at the mechanics about 1mnth ago to try and fix it ,They changed and checked spark plugs cleaned the afm changed the fuel filter and checked the ecu for anything and still nothing.but that was when the engine missing problem wasnt as bad and not a constant miss!!!!!!??!!
COuld the missfiring have gotton worse and maybe its forcing the cars ecu into limp mode?
Im taking it to another mechanic 2mrw for a diagnostic check to these guys just of christine ave (gold coast) i think they're called STOICHE correct me if im wrong ,but they have some bullshit performance cars there and can hopefully shed some light on my so shitty day.
I also bought a coil and tryed no change but i havent changed that oily black spark plug yet either ,all the other plugs were pretty white should i just throw them all and start over???
(car runs realy good after i reset the ecu still misses but it doesnt just die , until i turn it off.
Cars mods: 1 drift airfilter
Exaust only from the cat back 3'', and a earth kit if you can call that a mod but thats about it.
What should the standard oil pressure read when cruising at 60 (mine is just below 4)???????
Anyway fingers crossed for 2mrw!!!!!!!
Ok just walked back from mechanics after work not my favourite thing to do(walk) .
They havent fully sussed out the problem yet but they are pretty sure its a sensor.
I dont know what the f**k to do with getting realy frustrated with it?
Just wondering if anyone knows good mechanics on the gold coast with payment plans if any?????????????????????????????????????????????????
Because this is sounding expensive and it has been a real hard year on the wallet.
ok so i had to take the car back from stoiche performance but i will take it back to them 2mrw for round 2.
But for now can anyone explain what these bits and peices a i have pictured please?
this was a connection beside the afm dont know what it is. hers a better pic of it location
Edited by devos2be
some more pics of the disabled beast (stock pussy cat really)
The AFM after i cleaned the shit out of it the whole thing was pretty much coated in black shit.
How much do these things cost anyways..
Edited by devos2be
first picture is an electrical boost gauge unit.
i assume the plugs in the 2nd/3nd picture were together? cause they should be.
yeah what are they they're bloody filthy with gunky yellow shit all thru it or should it be like that???
Im thinking it could be your CAS. If it is a sensor you'll save yourself a crapload of money doing the ECU diagnostic which will tell you which one broken. Sensors are usually pretty cheap and easy to replace. O2 Sensors seem to be going left right and centre at the moment.
$300 for new Z32 afm
under $100 for 2nd hand stockie
either clean that spark plug in some petrol, or carefully with a wire brush etc or pay $4 for a new one. if it gets fouled again, there may b esomething wrong with that cylinder.
if there was oil gettting into the intake, it would be on all the plugs. either it is, and the other cylinders are happily burning it away, but no.6 is a weak spark etc. or the cylinder with the bad plug has bad rings or another problem. If your mechanic wants to rebuild it it may be cheaper to just buy a second hand engine rb20s are cheap as chips.
as a quick check, swap the coil and plug to other cylinders and see if the problem moves too. how does it run, obviously stalling but does it rev smoothly or sound like a tractor
Thanks for your feed back guys, as for the spark plug it only had oil on one, which i did attempt to clean.replacing today.Finally got the day off ill have a fiddle with it.
Was just wondering what CAS is????
But I really need to sort this car dieing on me all the time ,like the car has been missing for a mnth or so but this complete shut down shit just sucks?
Its like the car gets thrown into limp mode and wont push over 2500rpm.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
