F.s Qld 1993 Gtst R33 $10000
I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
