This as new (turbo's are less than 1000k old) full kit includes turbo's, wastegates (1.2bar spring), manifolds, dump pipes, TRUST front pipes (heat wrapped), intercooler piping (hot side only) and all braided water and oil lines (over $600 worth). Turbine housings, dump pipes and manifolds have all been ported and matched for increased air flow as well as been ceramic coated in "hi temp" black. Compressor housings and intercooler piping has been coated in "cerami-chrome". All ceramic coating cost over $1000. Makes over 500AWKW on 25psi and good for 9 sec quarters.
$5500
https://www.sau.com.au/forums/topic/190363-full-hks-gt-rs-turbo-kit/
  • 3 weeks later...
$5500
over 220 views and not even a nibble...dont buy a half done turbo kit for $3500 ( like this http://www.skylinesaustralia.com/forums/Fu...cm-t192192.html ) and only get turbo's and some intercooler piping...this is the real deal...not just a bolt on off the shelf kit but re-engineered to achieve maximum results. All HKS branded gear from the air filters to the cat flange (except TRUST B-pipe). Try buying all the parts modifying, coating everything then redoing all the lines in top shelf EARLS fittings (not cheap chinese sh1t). This set-up is producing over 5500rpm of peak torque and producing more AWKW than most big laggy single set-up's.
Buy your GTR a Xmas gift today!!
  • 6 months later...
whats on going on the car now?? i can see a low 9 sec pass coming
stepping it up...the car will go 9.7's with current set-up but whats the point only going a little bit faster.
when you can go a lot faster :D
Do you have pics of everything thats for sale?
right...ok...pics
turbo's and piping...all ceramic coated in 'ceramichrome' the turbine housings in 'hi temp black'
manifolds and dumps in 'hi temp black' (note manifolds for sale are brand new balance pipe items as shown in earlier post)
turbine housings and cores fitted with EARLS fittings
kit fitted up to engine
oil and water feeds
kit also includes HKS air filters and TRUST B-pipe
Edited by DiRTgarage
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
