Got a silver top, redtop, RB20de and a brand new in the box, bare, RB20det head.
Problem is the rocker boxes are off them and I cant tell which is which. The silver top (i think) is a complete top end. Its been decked as the guy I got them off was goin to do a RB30 conversion with them then went with a RB26 instead.
$280 for the silver, red and DE
$350 for the new RB20DET
https://www.sau.com.au/forums/topic/190372-cylinder-head/#findComment-3429508
I only need the head itself. If it has valves and lifters is OK (I'm stripping the valves and lifters out of my "dead" one anyway). And I have rocker covers.
How "decked" is the decked head?
And where are you located?
https://www.sau.com.au/forums/topic/190372-cylinder-head/#findComment-3430419
Dont know how decked it is as I got it that way as a job lot. The previous owner had it machined. He also scribed out the combustion chambers and was going to open them up to suit the rb30 the decided to go with a rb26 head instead.
Maybe the new rb20det bare head would suit you better. Its ready to go and you can put all your gear into it.
https://www.sau.com.au/forums/topic/190372-cylinder-head/#findComment-3432192
Well, where are you located? I'd like to be able to see them first.
https://www.sau.com.au/forums/topic/190372-cylinder-head/#findComment-3432331
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
