hey guys ill keep this as short as i can. i just blow up my stock turb so i upgraded to a highflow (only because i came across a cheep one). i figured i might as well get a fmic and high flow cat and dump at the same time. so my mods are...
highflow turbo
hf cat
3.5 inch exhaused (maybe 3 inch)
manual boost control
manual safc
splitfire coil pack
stock ecu (which i no is not good)
i got it tuned and it only got 166rwkws. and its pinning after 5800rpms. i was wondering wtf is going on? if i get a pfc will that fix it or is it something else? any advice would be muchly apriciated, thanx. :(
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/
If the tune is alright it could be your fuel pump. I think pinging's caused by your car running too lean.. backfiring is usually too rich. Although I know nothing about the quality of the manual SAFC's, I wouldn't imagine they'd be able to do too good of a job.
EDIT - what sort of fuel you running? 98 ron? BP ultimate etc? If running dodgy fuel your car will ping like crazy.
Edited by Simmo1985
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429326
im running shell v-power, the tuner also asked me about fuel. i have heard the manual safc's are good but im not to sure about that. thanx man
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429349
the thing is, before all the mods i was running 12psi getting 165rwkws, that was with smic, man boost cont and man safc. and stock turbo. and it was running like a dream.
rb25det? mate thats rubbish! mine got 180rwkw with only a pod and a turbo back exhaust!
but yes doesnt sound good at all. ive lost two engines, with virtually no warning whatsoever. i suggest you get it sorted asap.
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429374
shit thats not what i want to here!!
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429377
yeah mate... 166rwkw seems low
=( i made 201rwkw with just a cat back and 10PSI 'manual boost controller'. fmic.
i was running to lean... think it was coil pack that killed mine hey... wasnt firing or not enuff fuel
i'd say check ur plugs... my number #6 was white and thats the chamber i got probs wif now..
since i boosted mine i've had the problem...
=( getting engine checked to see wats got damaged now :turned:
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429794
It is amazing, some of the things I read on here!
FYI, and its been said on here a million times....
PINGING or DETONATION = LEAN MIXTURES! (In other words) NOT ENOUGH FUEL is being burnt with the amount of air in the right ratio.
If you upgrade all the air inducting and expelling items so the motor is moving more air = YOU NEED MORE FUEL!!
POWER= AIR+FUEL BURNT! UPGRADE YOUR FUEL DELIVERY SYSTEM AS WELL!!
THEN Dyno tune to get the Air/Fuel Ratio RIGHT!
https://www.sau.com.au/forums/topic/190419-ive-got-pinning/#findComment-3429824
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
