  • Replies 91
Posted Images
here is my rear wheel sticking out. Im still thinking whether to use flares or just roll the fenders.
the rear has a +10 offset. during the time I took the pic, the rear was in a negative toe since the hicas bar has not been installed yet so the wheels doesn't look straight.
iv actualy looked into re-drilling, the back part that meets with the hub has to be solid no holes or valleys, think it was like $85 a rim from somewhere in slacks creek, just have to keep my eyes peeled
those rears look pretty sweet, how wide r they?
i say decently roll em. flares are for wider rims, there nuffin worse then a car with nice wide flares/guards but u cant fill em in well, at least thats my thoughts :P
yea i see wat u mean, altho is $85 the cheapest you've seen? Edited by Dan_J
I'm having the same issue where it looks like the rim is too wide to pump the guard, but if I was going to have them flared I'd want to do it properly.. but then my rims wouldn't be wide enough lol I should've bought the 10" wide for the rear.
Edited by daisu
i never looked around for prices, thats a quote i got maybe 1 year ago, im sure if you looked around or knew the right people you could get it done for less..
bloke at works his brother has an import licence so im gonna give him some details and he gonna try find some rims in 18x9/10 round the 12+ offset for me.. what offset am i lookin for the front?
im also puttin off the re-spray till i get the rims, no point playin with freshly painted guards i figure
Mate don't go bolt on flares, those wheels will fit perfectly after flaring the back guards. What width are those rims? 9" or 10"? Couldn't make out in the photo if those tyres are 225/45/17's or 235/45/17's. You could also stretch those tyres a little bit more for more clearence, 225's if they're 235's or 215's if 225's.
Thats mad. What about front ? what offset ? What rim width? Tire sizes ?
Here are the wheel specs and tire size:
front- 17x8 +5 offset tires-215x45
rear- 17x9 +10 offset tires 235x40
I just mounted the front earlier and it just sticks out about an inch only so now, I opted to have my fenders rolled combined with a camber plate. :)
Dan_J,
I'll just roll them since the flares is actually my last resort if rolling won't be enough. :)
Hypnotik,
Yeah, I find the flares a bit out of shape for the car as I test fitted some. I prefer the stock looking body with rolled fenders. :)
Edited by CEF
for a 10 width in the front, you may still mount it up but you have to use coilovers so that the tires won't foul up to the stock spring perch. you may be required to maybe roll the fender a littlle.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
