  • Replies 94
The pictures are awsome the write-up is Fantastic if i do say so myself I kept it brief as to place extra info on the track etc!
I think this is great exposure for the club and also give some inforamation to Online members that may be unsure to join or come out on a track day!
So to all those that are wanting to come to events to see if you are interested in Track days COME! check it all out garantee it is the best fun you can have with your cloths on!
hehe u missed the point i think... :P
we were giving a demonstration of what some(one) of your nsw members do in vic section :)
If you don't like it, report it.. Simple as that. The mods will take care of the rest.
rofl now i get it
vics dont have anything better to do on sat night :P
atm have no car so nothing to do :)
geez relax re just a joke
Looks like you aren't the only one with no car :D
I know you guys were just joking but it does really clog up our section.
hahah @ victoria's revenge
Haha Hai LJ!!! :P
I'll be going down in Dec so I think I will pull a few good pranks.
u win this round :(
NSW always wins :rofl:
muahahah all true
#6 has made me cry into my wine tonight. 3 bottles so far
I've been thinking about that. But I'm so tired that I might pass out if I have a glass of wine.
I should come over and crash your party. :P I'm just down the road from you these days.
Looks like you aren't the only one with no car :)
Haha Hai LJ!!! :P
NSW always wins :D
hey corinne!!
where's your car?
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
