Holy Carp, what do you do to own the cars you do at that age? ^^^
OP: Very nice :) Given free reign, that's exactly the car I would buy. Yeah chuck on an exhaust, but plan thoroughly if you're gonna mod it :)
You asking me?? Got Boost answered anyway :D
Haha thanks! I got this direct from an importer. International Motor Group i believe they are called, really outstanding service thus far i couldn't be happier :) I can understand your excitement, i cant wait until next week!
I'll bet!! Congrats once again! I'm sure I don't need to say "enjoy" lol I know you will :spank:
  • Replies 59
Congratulation mate, i went and had a look at this car is well. The car is in excellent condition, i was about to put a deposit on this car but instead i put a deposit on a white vspec II which i have to wait till end of this year or early next year.
Btw. the car already come with a cat back exhaust.
Edited by oh-low
I recently had state roads do a full detailed report on the car, cost like $200 dollars but i think its money well spent and the report was very specific and thorough. Car got 95% in exterior, interior and mechanical so i'm very happy as i wasn't expecting the result to be that good! Id recommend this to anyone who is buying a car they want to be sure of, inspectors are very helpful and give you their phone number for further questions and contact.
Edited by Got Boost?
What can I say ... OOhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh whhhattttt aaaa feeling GT-R ... lol.....
Mind if I ask who much you paid, I guess over $40K?
Chuck a kit on it and get it tinted and you're done.
Was a fair bit more then 40 yeah, will be getting it tinted but i the kit will be remaining standard. I think they look tough straight from Nissan!
Cool another bayside blue V-spec II you will have to post up more pics when you get it, check out mine i have a few details and photos on its mods so far
http://gtr13.blogspot.com/
Nice work mate it looks great! Im organising the mod's im doing at the moment, will upload some more pics soon!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
