Greetings from the UK :thumbsup:
After the blown thermostat, broken thermostat housing, leaking water pump, and the slipping clutch, I've now got the fifth problem in as many months with this damn car.
I recently had a new exedy gtr clutch put in my R33 gtst and all was great for two weeks. Then i noticed a ticking noise from the gearbox at idle with my foot OFF the clutch. If i dipped the clutch a centimetre it stopped, possible the new release bearing collar rattling on the input shaft maybe?
This was pissing me off no end, having the car sound like a tractor at traffic lights, but then lady luck shat on my face once again and now my pedal has broken.
I pulled out of a junction, then mid change into second, heard a POP from the pedal and it rushed to the floor and i crunched the gear change.
When i put my foot on the pedal it pushes to the floor with hardly any resistance compared to how stiff it was, and i have to bury it into the firewall to change gear, then the second it lifts up a notch it engages and drives.
I had to finish driving to work like this and then home again. There is no slipping and the clutch seems to disengage fine when in gear. Its just a bugger to get into gear as i can't push the pedal any further down without coming through the bulkhead!!!!
Does this sound like hydraulics or has the pedal boxgiven up with the pressure of the new clutch???
Any help would be much appreciated as i need my car to get to work everyday !!!!!
EDIT: I didnt realise i hadn't posted anything yet. thought i had already said hi at least in another thread! Forgive my manners and my first post lol
Edited by reaver
https://www.sau.com.au/forums/topic/190644-clutch-pedal-woes/
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
