a 1993 R32 GTST 179000 on the dial Suspension was installed at 170000, engine was installed a 171000 as was the clutch, and the turbo has covered less than 2000 km
R33 RB25DET
20 thou oversize forged pistons
forged h beam rods
reconditioned (new springs valves ect) and lightly ported head
N1 oil and water pumps
ACL race bearings
Cometic metal head gasket
ARP head studs and rod bolts
R33 Gearbox
R33 Differential
Garrett GT3076R Turbo
Tomei Poncams
600cc injectors
Z32AFM
HKS Hyper 3.5" exhaust with custom front pipe
Splitfire Coil Packs
OSgiken TS2BD twin plate clutch rebuilt by NPC
C’s Short Shifter
GFB Stealth FX Blow off valve
Bosch 700hp rated fuel pump
Apexi Pod Filter
Apexi PowerFC
Greddy Profec B spec 2 Boost controller
Custom FMIC
Custom intake piping
Oil cooler and filter relocation kit
Suspension and Braking
HKS Hypermax 2 coil over suspension
Front and rear strut bars
B pillar Brace
After market sway bars
JIC adjustable castor rods
JIC adjustable upper arms
Whiteline Pineapples
R33 GTR Brembos with DBA 5000 rotors
Front: 17 X 8 wheels with 235/40 semislicks
Rear: 17 X 9 wheels with 255/40 semislicks
Exterior and interior
Full respray- Custom Blue
Genuine GTR Bonnet and Grill, Front bar, and rear spoiler
GTST Type M side skirts
GTST Type M rear pods
Genuine R32 GTR Front and Rear seats
Genuine R32 GTR Door trims
Genuine R32 GTR Headlights
Nismo Gearknob
Audio
DVD player with 4 inch screen
6.5" Jensons in the back and JL 6" Splits @ the front
Last tune was a very safe 260rwkw it was making 300rwkw previously but it was not safe, a safe 300rwkw is only a thicker head gasket away! At 260rwkw this thing still really hauls and handles beautifly too as it has that little bit of extra attention paid to the suspension
I am asking 24,000 neg. this price is mostly designed to ward off dreamers and tyre kickers, if you are interested we will talk! I have included a picture of the car with 18inch starcorp impuls, if the buyer perfers these wheels could go on the car instead as I still have them at home.
PM me to discuss the car. Hope to hear from you soon!
Andy
OFFERS AROUND 20K WILL GET YOU THIS CAR TODAY!!
https://www.sau.com.au/forums/topic/191365-1993-r32-gtst-with-rb25/
Thanks for the kind comments guys! It will be sad to see her go after all the blood sweat and tears but after the best part of 2 years i am ready for a change!
my kind of no bullshit car!
ive never seen it... shooooooooooow me.
you could but it and see it all the time :ninja: ha ha I will even give you a special members price :)
someone buy this car.....this is an awesomely kept and run car has everything you need and nothing to put in except fuel...
I have been in this car and its a wet dream on wheels.
  • 1 month later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
