a 1993 R32 GTST 179000 on the dial Suspension was installed at 170000, engine was installed a 171000 as was the clutch, and the turbo has covered less than 2000 km
R33 RB25DET
20 thou oversize forged pistons
forged h beam rods
reconditioned (new springs valves ect) and lightly ported head
N1 oil and water pumps
ACL race bearings
Cometic metal head gasket
ARP head studs and rod bolts
R33 Gearbox
R33 Differential
Garrett GT3076R Turbo
Tomei Poncams
600cc injectors
Z32AFM
HKS Hyper 3.5" exhaust with custom front pipe
Splitfire Coil Packs
OSgiken TS2BD twin plate clutch rebuilt by NPC
C’s Short Shifter
GFB Stealth FX Blow off valve
Bosch 700hp rated fuel pump
Apexi Pod Filter
Apexi PowerFC
Greddy Profec B spec 2 Boost controller
Custom FMIC
Custom intake piping
Oil cooler and filter relocation kit
Suspension and Braking
HKS Hypermax 2 coil over suspension
Front and rear strut bars
B pillar Brace
After market sway bars
JIC adjustable castor rods
JIC adjustable upper arms
Whiteline Pineapples
R33 GTR Brembos with DBA 5000 rotors
Front: 17 X 8 wheels with 235/40 semislicks
Rear: 17 X 9 wheels with 255/40 semislicks
Exterior and interior
Full respray- Custom Blue
Genuine GTR Bonnet and Grill, Front bar, and rear spoiler
GTST Type M side skirts
GTST Type M rear pods
Genuine R32 GTR Front and Rear seats
Genuine R32 GTR Door trims
Genuine R32 GTR Headlights
Nismo Gearknob
Audio
DVD player with 4 inch screen
6.5" Jensons in the back and JL 6" Splits @ the front
Last tune was a very safe 260rwkw it was making 300rwkw previously but it was not safe, a safe 300rwkw is only a thicker head gasket away! At 260rwkw this thing still really hauls and handles beautifly too as it has that little bit of extra attention paid to the suspension
I am asking 24,000 neg. this price is mostly designed to ward off dreamers and tyre kickers, if you are interested we will talk! I have included a picture of the car with 18inch starcorp impuls, if the buyer perfers these wheels could go on the car instead as I still have them at home.
PM me to discuss the car. Hope to hear from you soon!
Andy
OFFERS AROUND 20K WILL GET YOU THIS CAR TODAY!!
https://www.sau.com.au/forums/topic/191365-1993-r32-gtst-with-rb25/
Thanks for the kind comments guys! It will be sad to see her go after all the blood sweat and tears but after the best part of 2 years i am ready for a change!
my kind of no bullshit car!
ive never seen it... shooooooooooow me.
you could but it and see it all the time :ninja: ha ha I will even give you a special members price :)
someone buy this car.....this is an awesomely kept and run car has everything you need and nothing to put in except fuel...
I have been in this car and its a wet dream on wheels.
  • 1 month later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
