dont have myspace.
now i can appreciate that you are in your "ladies time" mate
but enough is enough. you arent worth a single drop of a peadaphiles crotch sweat.
my bad for the whoring.
Edited by r33cruiser
dont have myspace.
You don't know when to admit defeat do you. That's OK though....you are providing everyone with a good laugh.
You have been undeniably exposed as a wanker and a bullshit artist, but you continue with your pissweak attempt to save face.
You obviously have no shame, or no brain.....probably both.
Carry on......I'm loving it :)
All the off topic chat STOPS NOW!!!
r33cruiser, mitchy and lazy-bastard consider this a friendly warning to stop with the b!tching contest with each other or the next time it will be an official warning and a holiday...
The forum is here to aid ANYONE AND EVERYONE not to see who has the biggest e-penis :D
If you have a problem with another user or what they are posting then dont be like all the other terry tough nuts and bash that keyboard, send them a PM or a mod or if you think the post shouldn't stay REPORT IT.
Back on topic before i have to organise a group buy on Maxi pads for everyone :)
Cheers GMB
Can somebody give me a picture or link to those fancy fitting you have been talking about?
I need to mount three thermo couples, one in the airbox, one in the turbo hot pipe and and in the throttle body.
thanks chris these alloy nuts have to be available here, any idea who sells them (se qld)
cheers leigh
I bought a couple of the 1/8" weld on Aluminium Nipples from Motorsport Connections.
Cost me $25 delivered and I got a free hat!
shit i got to slow down and smell the roses,looked at m'sport connect and thought they were USA, what a great business, thanks BS,
i wonder if i'll get a cap
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
