  • Replies 95
there is no starbucks and i cant find your post office. Im sitting in the main street if anyone knows where the post office is let me know haha! P.s it smells here.
You suck at navigating brisbane!
lol u made a thread to say ur incompetently lost!!!. LOL
See the thing is I wasn’t lost I was walking around Moorooka waiting for my appointment and need a post office to pay my fine, turns out there was none to be found!
Farking no Star bucks either
Its the weetbix factory that smells josh... Go scam some freebies... since ur in town should come to willobank tonight, blacky is back together and were testing for jambo..
Doh! If i knew I would have stayed.
Nah wasn’t lost, just ghetto-vill in true Bronx style didn’t have modern amenities
i agree the south side of Brisbane sucks! :P
get a can of North side in ya...
north side blows goats, artifical fake suburbs mmmmmmmmmmm
i didnt know there was a centre link in Mooroka, I thought our nearest one was stones corner
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
