Hi ppls,
I'm about to outlay a few $$ on gauges in an attempt to keep an eye on things out at Mallala.
I'm looking at EGT, Oil Pressure and Oil Temp.
The others boost, water temp etc etc I don't need as thats what the PFC and Boost Controller is for. :mellow:
The guage I'm looking at is a brand called Nordskog.
They are a digital guage of which I like the idea of. Quick and easy to read; they also have a peak hold feature and able to display both F and C.
Here -> <CLICK> <- is where I'll be purchasing them from. I've bought bits from them in the past; can't recommend them highly enough, a MASSIVE range of silicon, extremely fast delivery with a no fuss bend over backwards service.
Has any one had experience with the Nordskog line of guages and the senders used for them?
https://www.sau.com.au/forums/topic/191541-nordskog-digital-guages-senders/
I'm pretty sceptical of cheap gauges, and they are very cheap. i've never heard of nordskod, sounds like a type of car built in the ukraine.
gauges are pretty important as they relay vital information. I would go for something proven like defi. accurate, peak recall, warning and record mode. they are top notch.
They work out a little more expensive than a set of Autometer guages; the prices on those gauges are without the senders and also in USD.
Not sure if I want to spend $700 on a set of 3 defi gauges though + I don't believe they make them in a 52mm gauge? :)
The Nordskog gauge appears to be well known overseas and I have seen them around when buying gauges for the boat etc. Apparently they are meant to be a good thing, just haven't heard much about them within the auto industry.
I'll try to dig up a little more on them before I make a decision.
25GTT,
The gauge number colour is available in Blue, Red, Amber and Green.
They also do universal dash panels that are all digital.
http://www.nordskogperformance.net/product...anels/index.htm
Also have the option to create your own combination.
http://www.nordskogperformance.net/product...ail/dp10003.htm
They appear to look like a good thing and after a little digging up they are definitely highly respected Marine gauges. No doubt their Auto gauges 'should' be just as good.
defi do make 52mm gauges but only in the 'defi link' series. Defi BF gauges are only 60mm.
yeah you are probably right and the defis are probably not twice as good (even though they are twice the price), but you have to look at them a lot and the defis are very fine gauges. TBH in day light the defi links are better than the BFs anyway. If I didn't already have 4 BFs I would get defi links for sure.
Don't get me wrong I would love a set of Defi Gauges. :)
I just can't justify spending that amount on the little old R32 GTST when it has so much more to be spent on it. It never ends. lol.
+ I'm not sure the other half would be too happy unwrapping a defi gauge for her b/day xmas. lmao
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
