Hi Everyone
Just picked up my 03 V35 350GT.
Love the car so far.
Just filled her up after getting about 380kms from a full tank. Is that normal for these cars?
It doesn't really surprise me, I used to drive a 3L 2JZ soarer and only got about 400kms from a full tank.
Anyway, i hope to learn a lot about this great car from the people on this forum.
Thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240086
Hi Everyone
Thanks
9
Hi Mick, congrats on your new car.
Check carefully what you filled to get 380klms ! . The car has an 80ltr tank. Im thinking you filled 50 litres or perhaps you only ran regular unleaded ??- not good- they need min 95 oct or higher. I only fill 98. On good run city running (syd) I get 550 to 600klm on a 70 litre fill or 8 to 8.5 klm/L.. The very worst even with lead foot all week is 500 on 70 litres. ( I hate that litres per 100 klms makes no sense to me especially when trip computer is in klms/L!).The light comes on at around 15L to go.
I managed 12.5k/L on the open road which would just about do Syd - Mel with a little city driving. Mines an "05, 6man coupe. I hope you misread your fill .Goodluck with the new beast!
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240110
I always have to translate km/L back to L/100km to make sense of it. L/100km is the industry standard. No idea why they show km/l in the V35, all the Aust. delivered Nissans show L/100km. I am guessing it makes it easier to convert the system for the G35, which is MPG, and a higher figure is better.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240720
Thanks for the replys.
It's a auto 350GT with 70,000kms. It just had a service 1,000kms ago.
I don't think it needs a tune. It runs really smoothly.
I have only filled the car once since I picked it up Sunday. I put regular shell unleaded(91 I think). Should I be using premium(V Power)?
I dont think that I have a heavy right foot haha maybe I do.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240867
You should be using at least 95, don't use 91 except in emergencies. you can get knocking with 91, and the ECU will retard the ignition timing to prevent engine damage, this will result in reduced performance and economy.
You can use 98 (V power) if you like, I didn't get any benefits from 98, but you can give it a try, some people claim to get better fuel economy with 98.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240892
1329555703[/url]' post='6240892']
Alright thanks.
Would it hurt putting some fuel injector cleaner in?
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6240901
Mick, cleaner wont do much. If I were you try to get 20 litres of 98 octane in asap. It will balance it out a little. As the handbook says use min of 95 octane. There is a slight improvement in economy on 98 and an improvement in mid range torque. I used 100 oct(shell) years back with my r33 gts t & unbelievable bottom end torque..Any car that has variable camshaft timing will see an improvement in performance/mileage. I only use 98 it looks after the engine on the long runm
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6241124
Itried 98 for a few months in my 350GT 6sp and also in my wife's J31 CVT Maxima(which also runs a VQ35DE), and saw no difference in economy, and no discernibleperformance improvement. Technically, there is no reason a stock NA enginetuned only for 95 should see an improvement or benefit from a higher octanefuel, regardless of VVT/VCT or not.
Some fuel companies may put extra cleaning agents in their 98 fuel, which maybe helpful.
However, many people claim to have noticed differences with 98, so it might beworth a try to see what you find.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6241512
Technically there is a reason why there is a diff. 3/95th to be precise or 3.166%. Your right in that its not discernable to many. Its about 20klms per tank. In terms of performance its a similar story. However ECU's drive engine performance based on fuel air mix sensors and if the octane is higher then it will make a difference dependant on the ecu & the engine.
NA motors and ECU like in Ferrari are a perfect example. Ferrari didnt inveet 100 million dollars in the development of Vpower for nothing.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6241581
TheVQ ECU can't determine between octane ratings, unless you run an octane too lowand it results in knocking, then it will retard the ignition. other than that,there is no difference in required mixture for higher octane fuel. Higher RONsimply means it has a higher resistance to detonation, it allows an engine torun higher cylinder compression pressure without the fuel mix 'self igniting'.A higher octane does not mean it has a higher energy density. Although it doesallow you to run a slightly higher spark advance in some situations.
As for the 3.166% difference, I get more difference than that from one tank tothe next, with the same fuel from the same outlet, and driving under the sameconditions. It would probably take me a year to get 2 tank fills with less thana 20km difference in range.
Not trying to say you didn't get a noticeable difference, just that I wouldconsider that figure well within the normal variations, and I would need afigure more like 8% to offset the cost difference.
As for Ferrari, I have no idea about their ECUs or their investment decisions,so I can't comment there.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6241870
So I put a full tank of v-power in today.
The fuel gauge was showing just under a quarter left of fuel. Could only take 55L ($90!!!! ohmy.gif).
I hade traveled 400kms with still 25L still in the tank (80L tank, correct?) on 91.
Not too bad. I have tried to drive a bit more economically.
Thanks for your replys again guys.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6242083
OK guys chill out.
The V has a common problem with the fuel gauges. You need to clean the sensors in the tank. Easy job.
When your fuel light comes on you probably have 1/4 still in the tank.
Pull your back seats out. Take the two lids off the tank, pull out the pump and sensors and rub the metal sensors with a cotton tip. There more detailed DIY do a search.
Good Luck
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6243038
Neat tip Paul, Sounds like Mick could use it.
Mick 400k on 55 litres of the wrong fuels is ok. Just hope no long term damage to the engine. Did ya notice any pinging from the engine?. Just check when your low fuel warning light comes on after the next few fills.
Once you get used to the trip computer you tell exactly how to much fuel needed to fill each time. I get it right to the nearest 1/2 to 1L.
Its not just a mileage thing you will notice How the car revs more easily from low speed all the way through rev range.It aint heaps but once you ve been driving it a while.
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6243329
Hi guys and girls, Ive had my V Coupe a bit over 2 months now. Street driving and track driving, I could not be happier with it. Coilovers are going in, in a couple weeks. I hope in the future I can meet some fellow QLD V drivers.
Cheers,
Sam
https://www.sau.com.au/forums/topic/191705-newbies/page/30/#findComment-6255711
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
