UPDATE:
After weeks of trying to find some rims that would suite the color and the lines of my car, i decided to settle for 18" Gravity Gullflame in Gold colour, 9.5" wide.
It's really essential for me to get the widest tyres available for a R33 GTST, so i was thinking 275's at the back and 245's at the front.
The 9.5" width rims come in these offsets: +15, +25 and +35
.. and the 8.5" width rims come in these: +25 and +35
Should I go both front and rear the same width rims? or Should i perhaps go 8.5" for fronts?
What is the ideal offset for front and rear wheels?
Do you think i could get same offset rims for front and rear on a gtst?
Help me plzzz..
Old post:
I've been lusting over these wheels lately, but can't seem to figure out what brand they are.
They can't be Wedsport SA-70's, although they look very much alike.
Can one one help me?
Edited by Barbarian
https://www.sau.com.au/forums/topic/191751-what-are-these-wheels/
Guys, another question.
What would be the best (like in that photos of Silvia above) for a R33, offset wise ?
The offset of the car above isn't THAT good. I mean it's got a wider body, but the wheels aren't close enough to the guards in my opinion. The front are alright though.
Try using this calculator mate.
http://www.1010tires.com/WheelOffsetCalculator.asp
Just experiment with different offsets and width to see how much the wheel comes out and see if there's enough room under your guards.
Thanks adam, much appreciated
God bless :rofl:
Hi Adam
In my defense, those pics were taken when I had a set of Ikeya Formula rear lower control arms in place and before I had a chance to get it aligned. I've since fitted the stock rear lca's and sold the Ikeya Formula ones (overkill for a daily), and the offsets are much closer to perfection. See the pics on the following post for proof:
http://www.sillbeer.com/2007/10/sillbeer-r...ther-stuff.html
Note that there's too much camber on the passenger side as it's yet to have an alignment (which will be happening tomorrow).
Cheers
Brendan
Help me plzzz..
Hi Adam
Cheers
Brendan
Sorry mate, I didn't mean to offend you in any way. Seeing that the car is used as a daily, I'm not surprised it doesn't have its tyres 2mm from the guards. :happy:
It's a beautiful car though mate. I'll be lucky if any of my car's will look like that. Take care of it.
Cheers
No wuckers mate. I was more surprised the many that putting the stock arms on would set the wheels up for almost perfect offset to the outside of the guards. But haveing said that, it means I can't lower it drastically without dialing a whole lot of camber in to tuck the top of the tyres under.
Cheers
Brendan
Help me plzzz..
If I were you I would go with the 8.5" at the front and 9.5" in the rear. I wouldn't have a clue how much clearance there is between your wheels and your guards, but I can help you out if you can get me some information.
Your current wheel specs:
I'll need your, wheel width, offset, diameter, tyre width and profile.
Your new wheel:
Just give me your desired width for the front and back and I'll work out which offsets I'd recommend.
Also how much clearance there is between your WHEEL and your guards front and rear.
If you get me that information, I should be able to help you decide which offset to go with.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
