UPDATE:
After weeks of trying to find some rims that would suite the color and the lines of my car, i decided to settle for 18" Gravity Gullflame in Gold colour, 9.5" wide.
It's really essential for me to get the widest tyres available for a R33 GTST, so i was thinking 275's at the back and 245's at the front.
The 9.5" width rims come in these offsets: +15, +25 and +35
.. and the 8.5" width rims come in these: +25 and +35
Should I go both front and rear the same width rims? or Should i perhaps go 8.5" for fronts?
What is the ideal offset for front and rear wheels?
Do you think i could get same offset rims for front and rear on a gtst?
Help me plzzz..
Old post:
I've been lusting over these wheels lately, but can't seem to figure out what brand they are.
They can't be Wedsport SA-70's, although they look very much alike.
Can one one help me?
Edited by Barbarian
https://www.sau.com.au/forums/topic/191751-what-are-these-wheels/
Guys, another question.
What would be the best (like in that photos of Silvia above) for a R33, offset wise ?
The offset of the car above isn't THAT good. I mean it's got a wider body, but the wheels aren't close enough to the guards in my opinion. The front are alright though.
Try using this calculator mate.
http://www.1010tires.com/WheelOffsetCalculator.asp
Just experiment with different offsets and width to see how much the wheel comes out and see if there's enough room under your guards.
Thanks adam, much appreciated
God bless :rofl:
Hi Adam
In my defense, those pics were taken when I had a set of Ikeya Formula rear lower control arms in place and before I had a chance to get it aligned. I've since fitted the stock rear lca's and sold the Ikeya Formula ones (overkill for a daily), and the offsets are much closer to perfection. See the pics on the following post for proof:
http://www.sillbeer.com/2007/10/sillbeer-r...ther-stuff.html
Note that there's too much camber on the passenger side as it's yet to have an alignment (which will be happening tomorrow).
Cheers
Brendan
Help me plzzz..
Hi Adam
Cheers
Brendan
Sorry mate, I didn't mean to offend you in any way. Seeing that the car is used as a daily, I'm not surprised it doesn't have its tyres 2mm from the guards. :happy:
It's a beautiful car though mate. I'll be lucky if any of my car's will look like that. Take care of it.
Cheers
No wuckers mate. I was more surprised the many that putting the stock arms on would set the wheels up for almost perfect offset to the outside of the guards. But haveing said that, it means I can't lower it drastically without dialing a whole lot of camber in to tuck the top of the tyres under.
Cheers
Brendan
Help me plzzz..
If I were you I would go with the 8.5" at the front and 9.5" in the rear. I wouldn't have a clue how much clearance there is between your wheels and your guards, but I can help you out if you can get me some information.
Your current wheel specs:
I'll need your, wheel width, offset, diameter, tyre width and profile.
Your new wheel:
Just give me your desired width for the front and back and I'll work out which offsets I'd recommend.
Also how much clearance there is between your WHEEL and your guards front and rear.
If you get me that information, I should be able to help you decide which offset to go with.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
