Well after a year of not owning a skyline there was a empty spot in my heart....
so i decided to fill it, and picked this up today
Car has a huge FMIC and a 3.5 inch exhaust stiill running standard boost.
Car has 83000km with history and the interior does not have 1 scratch on it. And its got a sunroof :P:D
Let the mods begin :)
Edited by krzysiu
https://www.sau.com.au/forums/topic/191818-im-backkkkkkkkkk/
Good work,
Expect to see you around again hey :D.
You sure will westy :)
Ill be round keysborough quite a bit as my gf lives there :)
I also got the old paperwork from when he bought this car!
He bought it from Power Road Car Sales in march for $19310
Ill be round keysborough quite a bit as my gf lives there :D
Cool :),
Wave when you see my BEAST, its also white..........mmm white Starlet lol.
Nice work, what mods you got planned for it?
And whats with the number plate hanging off the side :)
Im planning on changing the turbo sometime, but thats only when the standard one dies.
Need to also get some wheels :D - sif keep standard wheels!
Need to also get some wheels :) - sif keep standard wheels!
Ah nice nice. Thats what you say now!
2 weeks time you'l be like PFC, injectors, f/pump, high mount 3076, clutch, coilovers, LSD blah blah blah lol :D
hey kris - put up some more pics..... :)
Yeh get some interior & engine bay pictures up.
Edited by abu
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
