Hey guys, need help on guard rolling. I have just put a new front end on my car and the front guards need to be lip rolled and slightly flared. The reason why is the wheels have spacers front and back and dont want it to scrub.
Can i buy a tool that will do both of these? or when you roll the lip it flares the guard anyway???
If the tool is only 200 bucks or so, i will buy one and do it myself
I can do all steel fabrication,custom piping,tig welding and want to learn to do guard rolling! can anyone
help me out with this???, Thanks
https://www.sau.com.au/forums/topic/191950-guard-rollingflaring/
  • Replies 77
Posted Images
Nengun sell guard rollers
you can roll them and flare with these tools, but usually flaring requires body work and repainting.
i think the nengun ones is about $270 shipped
most places charge about $50 a guard
If you use enough heat and take your time you will be supprised how well you can flare them without the paint cracking.
Of course it does depend on the quality of the paint to begin with and if there has been any previous repair work.
You're best off buying your own guard roller. You can roll and flare your guards with the one tool. Like Craved said, most people charge about $50 per guard, but as far as I know, that's only to roll your guards not flare them. To flare, people charge about $65+. You can pick up guard rollers for ~$250, do your car and then flare 3 other people's cars and you've got your money back.
To minimize cracking and buckling, try flaring your guards on a really hot day so that your whole panel is nice and hot.
$250 seems more reasonable than $700.
There's someone on these forums who's selling a brand new guard roller for ~$220 I think it was. I just remember the member had a purple 32 GTR as his avatar.
Their was until I bought it :rofl: +1 for doing it yourself though keep in mind it takes time and patience to get the right result :)
Honestly.. on something where there is so much at risk - Id pay.. its not THAT much different in price..
Id be scared to bugger up the paint, finish, making sure its even.. But I also have next to no patience with fiddly things..
if it comes down to $200 for a roller.. and $300 to get it professionally.. Id personally get it done in a workshop..
This is not to say I like getting anything else in my car done by a shop.. I just think paint and certain body work things need to be dont proffessionally.. I dont trust other with any other area of my car..
you have to have faith in yourself, I have just stitched a new front on my car from strut tower forward and have never done it before. and am now going to do this surgery on a mates S15 which has the same accident and my confidence level has increased enough to do it. With this guard rolling i cant justify paying someone else to do it because they had to start at my level and you dont get warranty on this procedure, so where do you stand??? you might aswell give it a go yourself.
You just have to have the confidence in your work!!!!!!
Whats the worst that can happen??? stretch the guard!!!
Thats why god invented BOG.
And also i found these guard rollers
They are $175 at bursons.
Will keep intouch and tell all the outcome
I agree, you just need confidence in your work, if you don't feel confident, don't do it.
Where's this "bursons" place? What is it? Is it like Bunnings type place? :D
Serious question though.
Their was until I bought it I tried doing it myself, but ended up f**king it up.
Fixed.
Please use quote function correctly :D !!! As I didn't f&*k anything up when I did mine and it is the only car I do any work too!
-Phill
Edited by phillb
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
