Hello all,
I have never liked the shape of the older stagea although I have though many time...the running gear and specs were great.
I am looking to buy a Stagea..ARX..2004..with the VQ25DET motor and am interested
to know who hold compliancing for these things in Victoria...
I have searched on the Government web site and had no luck finding anyone here in Vic.
Can some one please direct me if they have one in Victoria and who they used?
Thanks in advance
Tekin
https://www.sau.com.au/forums/topic/191982-m35-stagea-compliancing-info/
Thanks for the heads up......maybe need to wait until I can get it done down here...
I have an importer that can buy and bring in the car..but am not willing to send it to Queensland...
Oh..anyone here in Melbourne seen one of these here or knows who has one?..I would love to see one in real life
# AR-X FOUR: A 250t FOUR (ie 2,5L turbo/4wd) model with increased ride height, leather, 18" rims and SUV-like body ornaments. 206 kW ELIGIBLE FOR IMPORT - COMPLIANCE UP TO 11/03 MODELS AVAILABLE
Out of the info on M35 Stagea Info thread http://www.skylinesaustralia.com/forums/t185569.html
Have you checked out the axis model? they are the ducks nuts tho the arx is good too. the styling on the axis i just love. i am really considering selling the 32 to get out of the performance car bit and get into a bit of luxury...
i beleive a place in sydney compliance them too..
Sending it to Queensland isn't too bad actually. Kiwi will drop it off there and truck it down for free I believe.
Your importer should know about this I think.
We've done it a bunch of times for some models we import that can only be complied there.
cheers,
david @ carizma
:P
Hello all,
Thanks in advance
Tekin
Hi Tekin
The ARX does have the VQ25DET motor. I just picked mine up in NSW from, http://www.northshoreprestige.com.au . He has a few ARX's in stock plus a great looking 250t RS FOUR with all the options.
Great car and so comfortable.
Cheers
Andy
  • 1 month later...
The ARX model doesn't have the VQ25DET - the only M35 with one is the 250T RX FOUR.
And you're correct - no-one in Victoria currently bringing these in at the moment.
This is incorrect as the M35 AR-X does have the VQ25DET motor. I have one and am going thru hell trying to get it complied. See several threads in the Stagea Discussion area
^^ ye thanx bud shoudlnt be too much of a swaet considering im 98% there with my F348 test car whereby all evidence were made in house at my workshop... wen its up il contact ya and save u the hassle and just plate yours :)
Is this for the post 11/2003 Stagea with the VQ25DET?
Cheers
Muz
^^^^^^^ sure is :)
Hi,
Let me get this clear as, like Muz, I have been sweating on compliance for a 2004 M35 with VQ25DET for more than 6 months (car in my garage in Brisbane).
You have a post 11/03 test vehicle that you are working on gaining emissions evidence for?
Where is the vehicle?
You are confident of a positive outcome with Vipac?
If this is the case, what sort of timeframe are you looking at?
regards
Matthew
And please excuse my ignorance but what is a F348 test car? I know of a F348 Ferrari but nothing else .........
Hi,
regards
Matthew
matthew,
my test vehicle is a 2002 build m35 stagea with a vq25det engine 4wd but im eligable to comply as late as the current builds. the car is yet to arrive in the country (early jan) and yes im very confident of getting approved to add this vehilce to my 9 or so other cars i can comply. emmisions arent an issue for me so its just basically waiting for arrival of the car and getting the ball rolling. I expect by march il be plating them
O really?
How come they are such a major issue for everyone else then?
If you are relying on a north Brisbane RAWS shop to sell you the evidence, you could be (like Muz and me) waiting for a very long time.
If you already have the evidence I will send you my car for compliancing...
matthew,
2002 Stagea can already be complied as all the testing has already been done! Post 11/2003 is the real issue as they have to meet the more (apparently) stringent ADR 79 standards.
As I said on the phone, you will have no problems with the 2002 car as it already complies.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
