i have a built 26 with a trust oil pump and recently installed a just jap oil cooler and connected my defi gauge senders up.
oil pressure is good driving normally, but when i boot it, oil pressure stays above 6 bar until it reaches about 6500rpm and falls to about 3.5 bar by 8000rpm.
rev limiter is set at 9000rpm so would probably drop below 3 bar by then :thanks:
i also have fresh oil in there, castrol edge 10w-60
thanks,
luke
could be a myriad of things, the cheap coolers are not real good for flow but we ran twin JJR coolers on the car in my sig with no issues. remove the inlets and check to see if the inlet is half covered... some of them are and these coolers are useless. If it isnt this i would suspect incorrect clearances by whoever built it..
thanks for your reply,
what do u mean by check if the inlet is half covered?
another question, is it important which way the oil flows? ie. engine > filter block > cooler > back to engine
Edited by luke20t
thats called oil surge mate.
next time it does it. just stop acellerating. and it should leval out. basicly keep filling oil till it stops surging.
even though the sump is baffled and the oil level is almost on full on the dipstick?
depends what sump you have, stock gtr sump wont but if your running an rb rwd sump (assuming the car isnt a gtr) then there is every chance no matter how much oil you stick in there it is going to surge.. mine was the same
added more oil..
booted it a couple times and the oil pressure seems to be holding above 6 bar.
i cant believe how much oil i have put in now! close to 6.5 litres!
just hope this wasnt happening b4 i put the cooler in, because i never had it so full.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
