it just looks a little too rich to me (good cos most r32's I have seen run lean)
note how the ecu has richened up the the fule for a second when boost came on at about 3200 rpm and then nealy over compsated for it.
With regards to your question the right hand scale is A/F 11 is rich
14 would be too lean your car dosn't look to bad.
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-403199
It has a different turbo....it was on it when it came from Japan. Not too sure what it is but looks similar to a 2530. Other mods include 550hp intank fuel pump, bleed valve set to 13psi, 3inch zorst turbo back, air pod. Standard computer, no AFC, standard injectors, standard intercooler. Next mod for me is definately the front mount!!! I want over 200rwkw....then i'll be satisfied.
Scott.
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-403423
standard cooler! wow! you must have a pretty efficient turbo to pull that power and run safe with a standard cooler, whatever it sounds like it works well!my dream would be to have an HKS 2530 on mine.
let me know how it goes when u get that cooler fitted and the boost wound up no doubt :)
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-403451
Don't slap a fuel pump on it unless you really need it as you will loose power.
UNLESS you have a fuel comp and are going to tune it when you fit the bigger fuel pump.
The bigger fuel pump made mine loose almost 20rwkw and the AF's were around the 11's origionally like yours.
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-403787
Guest Boxhead
well to ad confusion or not haha, can someone tell me exactly what my a/f are doing?
they basically run just below the 13 all the way along except for the end of the dyno were when teh power starts to die off it starts to raise just above 13, and looks like if we kept going it would keep rising..
sorry i couldnt post a pic as some how the usb cable for my cam is lost...
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-404245
impressive Bbenny.
I had my R33 dynoed at procar a few weeks ago and managed 252rwhp at 0.8bar (about 12psi).
I got Paul and the team to tune my powerFC and from memory they managed 220rwhp @ 6-8psi or so.
My AFR stayed constantly 12 across the range.
Knowing nothing about dynos, maybe they didnt set the computer up correctly to mirror what revs your car was at?
Mine was the same - I was in the car and I can assure you that they took it past 5500rpm.
Mark
https://www.sau.com.au/forums/topic/19202-dyno-print-out/#findComment-404857
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
