which maccas you near bob?
ASPLEY...
I pick up a 2002 Corolla Conquest today so that I can go past without wankers being wankers...
The line is going off the road for a while while I replace some parts, do some polishing and a general tidy up...
Its been a daily for almost 2 years as I sold my n15 SSS to help with spending money for NYC at the start of the year...so it needs a few things!!!
saw a white 33 pulled over in moss street, springwood at around 10am on sunday. feel sorry for you, hope it wasn't too painful.
is autobarn the latest hotspot for the cops?!?!
Im looking for GTR R32 air flow meters if any one knows any one or any where to get them i'm on the gold coast please let me know. And say Hi if you see me driveing its gun metel grey, gold AVS rims, im always in surfer or around that area. Thanks Guys & Girls
OMG that was me!!! (near autobarn right??)
Bastards defected me, bov, pod, steering wheel, boost gauge. Ticked 'major' defect now i gotta get it inspected by queensland transport. :D
Yep that must have been you. Really sorry to hear about the defects. The cops are being real pricks at the moment. We were the silver 32 that drove past you a little slowly, not to gawk, but we didn't want any attention from the cop!
I think next time i go to autobarn i'll take someone elses car. You are the third car in as many months that i've seen pulled over in that area.
Actually i didn't notice you, sorry. The only people i saw drive past were old people with the "cop that you bloody hooligan" expression, like i'd been caught doin 120kph or something <_< (you're not old are ya :lol: )
You needen't have worried, i had the cops full attention, could have pulled a skid right infront of us i reckon.
And yeah, wont be going back to that store anytime soon. Betcha he was waiting round the corner for a 'hot' car to come out of autobarn..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
