spotted a black r35 coupe, around 2;30 - 3 with black rims with the chrome lip driving past the norhtlakes in balance gym / pub ( i was inside gym staring out the window :P ) BUT you came out of the street my car was parked on.
anyone here?
spotted a black r35 coupe, around 2;30 - 3 with black rims with the chrome lip driving past the norhtlakes in balance gym / pub ( i was inside gym staring out the window :ermm: ) BUT you came out of the street my car was parked on.
anyone here?
R35??? :P I think u mean V35??
spotted today, a black V35 :) coupe. female driver, i was inside the gym and watched you try to park like 3 or 4 times ;) then i saw you walk into the same gym :D
car has ray white stickers on the side anyone on here?
fair fair. i know the one i think there are two otehr gunmetal 4 doors in noosa one has paint falling off it and owned by a old woman and the other well i only seen it occasionally
The one in my street is the paint falling off one, unless there are two of them lol
spotted Silver R34 "UR FACE" at gateway today.. give you a wave but not sure u seen it ???.. :)
Sure did see you wave, mind you that tint is damn dark... :)
Also saw DFT32 (Black 32) pulling into a place of work at Cannon Hill
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
