My advice is to stay well clear of keep left signs late at night if you don't want to need to replace your bonnet! :uh-huh: *Trying to learn from past mistakes...*
At Least it was a good excuse to spend a ridiculous amount of money on mods... :)
Yeah, I have been looking at that s15 too, looks like a drift special straight from Japan. Hey Moggy, whats the finish like on that bonnet, I have been looking at those bonnets on there website for a while now. Which one did you get? Last time I was at their shop they were pushing hard for me to get one but, no money and didn't fancy carring one home on the plane! They look very nice though.
Hi, just dropping by lookin at all the sweet sweet skylines....*drool*
well im always looking out for them whenever im driving about around the Tweed/Gold coast areas. Saving for my very own skyline. The thought of one just makes me need to change my pants. *blush* heading up to brisse on sunday to wander the streets looking at the pretty cars ^_^
anyways hopefully ill get one by the end of the year or early next one. But someday ill get it! ;)
Saw a couple about a month ago parked one maroon skyline near the casino i had a nice look at forgot what model heh ^^; But still always nice to see some go by ;)
well might go play some Inital D at Replay. played it last time and now i must play it more! lol but not ganna spend to much on it cause i want the real thing ;)
I thought the finish was excellent - a lot better than I thought it was going to be, in fact. Very glossy, and you can't see any break lines in the fibres where they used more than one sheet (if they did). I got the one they advertise for the series 1, with the vents over the radiator and above the turbo (fair bit of heat comes out of that one). I actually had to wait a few weeks for one to be available cause they sold out and were waiting for a new shipment. They said that they go pretty quick - don't know how accurate this actually is...
I think they're pretty good if you can justify the price (they definitely look best on a white car, I think) but I can tell you that since I got it (only a week ago) I've been stared at by every single copper I've passed regardless of what they were doing and I think I'm going to be pulled up a LOT more than usual (which is not very often at all). :P We'll see...
Someone organise a cruize soon if not i will.KIf no one posts a thread let me know i would like to see a crew of us out at willowbank .Cmon dont be scared.I know some of you are we are all friendly and no one is going to laugh at your times?if anyone is keen put them on here.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
