My advice is to stay well clear of keep left signs late at night if you don't want to need to replace your bonnet! :uh-huh: *Trying to learn from past mistakes...*
At Least it was a good excuse to spend a ridiculous amount of money on mods... :)
Yeah, I have been looking at that s15 too, looks like a drift special straight from Japan. Hey Moggy, whats the finish like on that bonnet, I have been looking at those bonnets on there website for a while now. Which one did you get? Last time I was at their shop they were pushing hard for me to get one but, no money and didn't fancy carring one home on the plane! They look very nice though.
Hi, just dropping by lookin at all the sweet sweet skylines....*drool*
well im always looking out for them whenever im driving about around the Tweed/Gold coast areas. Saving for my very own skyline. The thought of one just makes me need to change my pants. *blush* heading up to brisse on sunday to wander the streets looking at the pretty cars ^_^
anyways hopefully ill get one by the end of the year or early next one. But someday ill get it! ;)
Saw a couple about a month ago parked one maroon skyline near the casino i had a nice look at forgot what model heh ^^; But still always nice to see some go by ;)
well might go play some Inital D at Replay. played it last time and now i must play it more! lol but not ganna spend to much on it cause i want the real thing ;)
I thought the finish was excellent - a lot better than I thought it was going to be, in fact. Very glossy, and you can't see any break lines in the fibres where they used more than one sheet (if they did). I got the one they advertise for the series 1, with the vents over the radiator and above the turbo (fair bit of heat comes out of that one). I actually had to wait a few weeks for one to be available cause they sold out and were waiting for a new shipment. They said that they go pretty quick - don't know how accurate this actually is...
I think they're pretty good if you can justify the price (they definitely look best on a white car, I think) but I can tell you that since I got it (only a week ago) I've been stared at by every single copper I've passed regardless of what they were doing and I think I'm going to be pulled up a LOT more than usual (which is not very often at all). :P We'll see...
Someone organise a cruize soon if not i will.KIf no one posts a thread let me know i would like to see a crew of us out at willowbank .Cmon dont be scared.I know some of you are we are all friendly and no one is going to laugh at your times?if anyone is keen put them on here.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
