I saw Glenn this morning ;)
yup yup... i had this feeling that it was you along coro drv. was on my way home from the city ... gave you a double hoot, hoping you heard :)
you turning into Toowong carpark aren't you?
black 33 at indooroopilly this morning at about 10:30
you were in indooroopilly and you did even bother to drop by and say hi to me?? :)
was washing and waxing and counting the number of scars i have on my car the whole day saturday.... :blah:
Sorry dude....had no idea you were there.....
BASTARDS!!!!....I love the drive through Mt Glorious/Nebo
Prolly wouldn't have been able to come anyway, coz the missus had just got back from a week in Townsville.......I wouldn't have been a popular boy pissing off for the night after not seeing her for a week.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
