  • Replies 71
My boss (great bloke that he is) has agreed to let us use the carpark at my work. It is in Fyshwick, so it is easy to get to; it's plenty big enough and it's under cover, but still gets plenty of natural light. Only issue is that it would have to be either this sat (17) or next sat (24).
Oh, it is also secure, so we won't have any randoms to contend with and as long as everybody behaves themselves we will be able to use it again. Feel free to PM or call me to organise a time.
0416 051 224
Donnan :P
That sounds fantastic.
But I won't be able to make it. Both those Saturdays are out for me. I'll just do my car elsewhere, it's all good :D
Can someone make a decision, days are running out.
Bullet32 can you pm Ladybytes your number? Ladybytes this is your great idea,(as in, it is a really good idea) so can you talk to Bullet32 and choose a time/date.
Bloody quicker than saying maybe this time/location each couple of days on a forum.
I KNEW IT! I knew this was something more than just Michele's love for good tyres! :)
Ps: this is my 100th post yaaay :PBJ:
Yeah... we go through a fair bit of rubber between us :rofl:
HEY!! A girl can dream can't she?
Okay, I'll phone Michael now... but its up to you guys to repay the favours LOL
Sat morning early is out for me, but anytime after about 10:30-11am I should be okay.
Brendan - Fyshwick sounds like a great plan too thank your boss for us. What times work for you?
Michael, is Saturday lunchish/just after lunch okay with you?
If youre talking about this Saturday (as in tomorrow) then sorry Im not available, I have a 25th to go to... Sunday is out aswell.
Sorry :rofl:
I know that the election is on the 24th and some have other commitments, but how about this:?
Everyone gets up early and does the voting thing, then meets at the Fyshwick car wash on Canberra Ave at 12pm for a final rinse off (the cars people, get your mind out of the gutter).
This will allow time for a few stragglers before we head to my work (pretty close by) for the workshop.
Mick, i know it will depend on numbers but, how long do you think it will take? And, what did you have in mind to show us?
Sounds goooooooooooood to me. Please count me in (SteadyEddy cheated and got his detailed).
Gutter? What are you suggesting? My mind was never that high up *innocent look*
As per my previos comment ;) no no, really, wotcha gonna show us Michael? *refrains from saying frangipani boi*
wont be able to make it but still need to really clean my car, the white on the car is slightly yellow, only noticeable when i put the new boot and spoiler on and the new rear garnish. Anyway, cut and polishing, what do i do? Do i wash car -> cut and polish -> wash again? Or just the first two?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
