Hi there,
I have a VG30 on my RB20DET R32GTS4. I am now tired of reaching full boost at / after 4,000 rpm and have decided to swap to an RB25 turbo. Searching through the forum I understand that the R34 GTt exhaust housing is the same size as the VG30. My understanding was that the lag was caused by the large exhaust housing which leads me to believe that this swap is a bad idea.
I do however understand that the turbo core and compressor / compressor housing is 'better' in the R34 GTt turbo.
I am interested on your thoughts as to whether or not this swap is worthwhile. After some reasearch I understand that a turbo from an R33 (eithe S1 or S2) will alleviate some of the lag. If the R34 turbo is a bad idea, I will go for a r33 turbo.
Your thoughts?
Edited by Birth
https://www.sau.com.au/forums/topic/192404-r34gtt-turbo-vs-vg30-on-an-rb20det/
mate,
i got an r33 gcg highflow on my rb20det, starts boosting just over 3000rpm and doesnt hit full boost till 4000ish..but comes on hard after that!!!
now i dunno if there is sumthing wrong with my car and ths setup aint right...but thats my circumtances...so im considering chances turbo's to recude lag..i honeslt dont giv to farks about top end...i mean not lose heaps top end ..but i would sacrifice top end for less lag and bottom end.
what ecu u plan on using? im using std ecu with fuel cut defender..not that good to be honest..
Your turbo behaviour sounds exactly like mine (though I imagine yours comes on alot harder than mine). I don't mind my car when I am driving around that suburbs where there is less traffic etc, but I live in the inner west and traffic and lights etc. mean that I am never on full boost and makes the car a bit of a pig.
I will continue using my ecu which is a Tilbrook Auto tune which I modded slightly at home with ROM Edit. I use an old 5-pot Apexi SAFC to make minor changes, but I haven't made any in ages.
i was looking on ebay at those e prom things u can put in ur std ecu? supposively improves ur mid range...and it would be great to get sum of that. besides wats the point of running 14psi when u dont get it till 4-5000 rpm...annoying.
anyone had experiences with these things?
YEh.. one of the r33 s1 or s2 has a nylon wheel which is easier to spool up. my mate has one on his rb20det sylvia boost around 3. I have a sliding performance high flow boost around 4.5/5 grand bigger house in compressor and exhaust sizing witha steel wheel..........14 psi at 5000 rpm....... ANNNOYING
Weird some of you guys have a very laggy VG30.
My VG30 hi flow on my R34 gets to full boost at 12psi at about 3600rpm, making 240rwkw with just that 12 psi. At 1 bar hoping for 250 or more after i get a better aftermarket ECU.
the only reason urs is hittin boost earlier then the other pplz on here is coz u got a 34 which is 2.5 litre, we all got 2 litres so the bigger turbo takes longer to spool.
pplz u just gotta remember that these turbz were made for a 3 litre twin turbo not a 2 litre single, hence why comin on boost late.
the best way for great power and early boost for all the 32 boys out there is to get a HKS 25/10, small but still packs a shit load of a punch.
btw i got vg30 on mine n it sucks for drifting but love it on the road coz the V8 boys think there winning then all of a sudden boom u pass em, mate its soo good lol
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
